weird sound??
Old Feb 21, 2009 | 05:20 PM
09blkgtcal's Avatar
09blkgtcal
Default weird sound??
Hey guys, I have an 08 gt with a jlt and a tune. Recently I started my car after I had left it outside over night probably around 20 degrees and when I started the car the next day there was this whistling sound coming from the front end. idk how to describe it but I will try and record the sound if it happens again. It has happened 2 or 3 times any know what this is?
thanks
Old Feb 21, 2009 | 06:08 PM
OhioState87's Avatar
OhioState87
JLT sucks in more air and makes a whistling/air sucking noise. Being colder, it was revving higher on startup, possibly causing you to notice this sound?
I know when I'm driving and have my foot on the gas, I can here it "whistling" as it sucks in air.
Old Feb 21, 2009 | 08:16 PM
Nuke's Avatar
Nuke
There's a TSB for that. The noise should go away after it warms up. I'll try to find it and I'll edit my thread.
Edit: http://francesco.maxdsl.de/documents...B/08-04-02.pdf
Old Feb 22, 2009 | 10:32 AM
09blkgtcal's Avatar
09blkgtcal
thanks guys, I just wanted to make sure it's not gona cause damage to the car. It makes the sound twice for like 2 seconds each time right when I started the car if that helps
Old Feb 22, 2009 | 10:34 AM
09blkgtcal's Avatar
09blkgtcal
When I drive around and get on it I hear the whislting/sucking sound from the intake this is a different sound. But ya mayb its because it was cold
Old Feb 22, 2009 | 02:04 PM
rmssch89's Avatar
rmssch89
I've also got the JLT and I've noticed the same thing. It's nothing to worry about. With the engine cold I can hear a whine of sorts when I get on the gas, but it goes away once the engine warms up.
Old Feb 22, 2009 | 02:39 PM
East87's Avatar
East87
It's the fead idler pulley causing a whistling on freezing cold idle. There's a TSB out on it.
I'm getting my car checked out at a dealership sometime over the next couple of weeks. Happens on mine after it sits in the garage on a sub-freezing night. I don't have any intake upgrades.
Old Feb 24, 2009 | 12:14 PM
09blkgtcal's Avatar
09blkgtcal
thanks alot guys. Im going to bring my car in for service soon, do you guys think I should bring this issue up or just leave it alone
Old Feb 25, 2009 | 04:31 PM
09blkgtcal's Avatar
09blkgtcal
anyone???
GimpyHSHS
19
Dec 19, 2023 01:12 PM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
KingRando
Oct 2, 2015 08:06 AM
mungodrums
Sep 28, 2015 10:54 PM
