Sequential / Chase Tail Light Help....
Old Mar 10, 2009 | 11:10 AM
  #41
thedrod's Avatar
thedrod
Originally Posted by Allstar
haha..
well as a customer from meter4it. the kit was a little more expensive but it was definitely worth it. I love the chase lights because it just flows so nice. Plus if I want I can just pop open the trunk and by switching a jumper in 2 seconds have sequential lights. The install took me about an hour and a half I would say. I took my time and wired it all nice (even found a dollar bill behind the passengers side rear panel (beneath the quarter panel window)). The install wasn't bad though other then the fact it was cold and dark and my X gf was being a jabroni. I would still recommend it to anyone over the plug and play kit. Gives you that little thought in your head which holds you back from buying any other mod's right away because your happy with them.. atleast for me.
I had just finished a full blown audio install on my mustang before I was looking into what sequentials to buy. The thought of pulling all the trim up again to run a wire was not appealing.
I honestly don't know if I have the room to run anymore wires!!! The passenger side has 6 pairs of speaker wire, along with 3 pairs of RCAs, and a remote turn on lead. The driver side has a gi-normous 0 gauge power cable. A dollar bill wouldn't even fit......
I love the way the chasers look....but I think I'll manage with the normal sequentials.
Old Mar 10, 2009 | 11:34 AM
  #42
Allstar's Avatar
Allstar
haha wow.. yah i hear you on that. where did you fit the 0 gauge wire? did it fit under the door sill?
Old Mar 10, 2009 | 01:02 PM
  #43
thedrod's Avatar
thedrod
There is a Amp Install write up on here someplace. I pretty much followed it.
I ran the 0 gauge wire down behind the battery tray and into the wheel well. I had to remove the inner fender/wheel well plastic cover and feed it through the existing factory grommet, (yes it does fit perfectly) then ran it down the side with no fitment issues. Worked out pretty sweet.
The biggest pain was running new speaker wires into the doors.
Old Mar 10, 2009 | 03:38 PM
  #44
jf713jf's Avatar
jf713jf
Originally Posted by Nuke
I can't see my rear blackout panel and it was worth every penny! Definately a must-do visual mod. Of all my visuals (see my sig), the sequentials get the biggest thumbs-up.
The plug-n-play models take maybe a whole 20 minutes to install including slapping everything back together. It's very easy. Plus, you can reinstall your stock harness in the same time (or less since you already know how to do it) if you ever feel the need.
I just had to do a minor "fix" on mine from American Muscle (they're made by Stack Racing) and also installed a set in my g/f's '06 Pony. $139 + shipping but if you watch you may be able to catch them on sale.
Well i mean I think his point on not being able to see the lights was based on the fact that when your oudside your car, there's no reason or way for your lights to be on. You would still be able to see your blackout panel when you walk up to your car, but your tail lights would be off.
Old Mar 10, 2009 | 03:40 PM
  #45
Nuke's Avatar
Nuke
I guess I'm weird then (but most people already know that...) since I'll turn my 4-ways on just to watch my sequentials on occasion.
Old Mar 10, 2009 | 04:26 PM
  #46
157dB's Avatar
157dB
Cut & Paste Expert
If you truly needed an 0 guage power wire, it would have
been better to run a 8 guage back for charging purposes and
have an Optima Yellow Top in the trunk with the amps.
The resistance alone is enough to warrant the trunk mounted
battery.
Old Mar 10, 2009 | 08:20 PM
  #47
gedyup's Avatar
gedyup
I do the same thing. So I guess I am weird too....lol. I have sequentials on my 05 (plug and play) and love them. Have not had any problems with them at all, so far.
Old Mar 11, 2009 | 10:09 AM
  #48
thedrod's Avatar
thedrod
battery.
I know this is the wrong thread for this convo, but I ran the 0 gauge for future headroom. I do not need it right now. I am running all of the JL 450/4 channels on the fronts and a small 400rms amp for 1 10 in trunk...for now.
Old Mar 11, 2009 | 10:31 AM
  #49
rehtorb's Avatar
rehtorb
I just did a meter4it install this weekend and it went fine. I soldered the connections to be on the safe side.. also the lights sequence when i arm the alarm so i get to enjoy it every time i lock up
Old Mar 11, 2009 | 10:38 AM
  #50
jf713jf's Avatar
jf713jf
It doesn't really matter to me, but you might just want to start a new thread for the audio wiring topic just so that if someone were to ever use this thread for reference they wouldn't get confused with all the other wiring stuff being discussed. Like I said, it doesn't really matter to me because all my questions were answered by you guys (I thank you very much ).
