air pressure
Old Feb 26, 2009 | 05:33 PM
deekum1627's Avatar
deekum1627
Question air pressure
i have kdw2 it says 51 psi max on the tire i put in 45psi, what should i have in it
Old Feb 26, 2009 | 05:55 PM
Goldenpony's Avatar
Goldenpony
Default Tire Press?
ME? I use what Ford says on the door frame, plus 2 psi.
Old Feb 26, 2009 | 05:56 PM
cegha's Avatar
cegha
I believe recommended tire pressure is only like 35 psi.
Old Feb 26, 2009 | 05:57 PM
deekum1627's Avatar
deekum1627
diff size tho you can do that unless its the same tires size
Old Feb 26, 2009 | 06:19 PM
SikO7GT's Avatar
SikO7GT
Idk what to tell ya deek try looking at their website and try to find out!!
For winter i try using a lower tire pressure so that you can have the maximum rubber hitting pavement!!
But during the summer i turn it up to about 36 for better tread life!
Ford recommends 34 on the stockers!!
Old Feb 26, 2009 | 06:31 PM
jahudso2's Avatar
jahudso2
what size tires do you have now? running 45 psi seems a little excessive. unless you are on really low profile tires, you are just reducing your contact patch and therefore grip.
Old Feb 26, 2009 | 06:37 PM
Bmr4life's Avatar
Bmr4life
isn't air pressure tire dependent?
Norm Peterson's Avatar
Norm Peterson
Depending on what your car's OE tire size was your door sticker will list something in the 32 to 35 psi range. If your tires are not an OE size, you may need slightly different pressure, but it should not be much different. It's also OK to vary slightly from the door sticker pressures as long as you have a good reason for doing so.
The max pressure number molded into the tire sidewall is a tire maximum and has absolutely nothing to do with what you should run that tire at on any given vehicle. Except for a couple of extremely unusual situations, you might just as well forget that the tire sidewall max number is even there.
Norm
Old Feb 26, 2009 | 08:56 PM
Nuke's Avatar
Nuke
The door sticker probably says 32. Mine does. I run mine at 34-35 PSI. But it all depends on what your preference is. Start at 32 and increase by 2 PSI increments until the ride gets uncomfortable. Based on whats been said in the handling forum, about 35 is a good compromise. What's on the tire is a max pressure and NOT a recommended pressure for in-service use.
Old Feb 26, 2009 | 09:08 PM
deekum1627's Avatar
deekum1627
yes, i have 295/35/18 rear and 255/40/18s front ill try to cjeck there website and see what it says if nothign there then ill call a tire shop and see what they say
