air pressure
Old Feb 26, 2009 | 10:14 PM
owero01's Avatar
owero01
I run mine at 35 psi. I would go much higher than that.
Old Feb 26, 2009 | 10:56 PM
gtguyonli's Avatar
gtguyonli
I run 35 on mine also, even though I have 20" wheels.
Old Feb 27, 2009 | 06:24 AM
Norm Peterson's Avatar
Norm Peterson
Originally Posted by deekum1627
yes, i have 295/35/18 rear and 255/40/18s front ill try to cjeck there website and see what it says if nothign there then ill call a tire shop and see what they say
In terms of load capacity, your rear tires are the same as the 235/50-18, so I'd treat them like 235/50's in terms of inflation pressure. 32 is the door sticker pressure for those; where you go from there is up to you. I would suggest keeping an eye on the evenness of trearwear. If you rarely have back seat passengers or heavy trunk loads, 30 is probably adequate here (and you may find that it helps the rear be better-behaved).
Your front tires are a couple of load index numbers smaller than 235/50-18, so you need about 3 psi more to maintain the same load capacity.
As I understand it, tire load capacity is related to how much it deflects/distorts in service, which is related to heat buildup.
Try starting with 35 front, 32 rear with that combination and tune from there. For a little less understeer as long as you're lightly loaded, 36/30.
Norm
Old Feb 27, 2009 | 11:03 AM
deekum1627's Avatar
deekum1627
thanks for the help guys ill let you know what i do
Old Feb 27, 2009 | 01:02 PM
CutterWolf's Avatar
CutterWolf
A good rule of thumb is between 35 to 40 psi if your running low profile tires. I run mine at 40psi for 3 reasons, 1. Pot hole rim protection. (hit a unforseen pot hole at high speed with an under presure tire and your going to do damage to the wheel or worse have a blow out) 2. Max MPG, (low presure tire means less MPG) And 3. Tire wear, (low presure makes more friction and causes your tires to wear out faster). On 40 psi in my 265x35 20's the ride quaity is still good
Old Feb 27, 2009 | 01:17 PM
deekum1627's Avatar
deekum1627
i put in 35psi see what happend maybe ill go 40 psi sound better to me
Old Feb 28, 2009 | 07:34 PM
Art161's Avatar
Art161
Originally Posted by SikO7GT
For winter i try using a lower tire pressure so that you can have the maximum rubber hitting pavement!!
This is old-school thinking. Today's tires not only have sophisticated design when it comes to tread pattern, but they also have sophisticated design when it comes to tread compound. The tread compound is often quite different on the edges of the tires than it is at the center. You are usually better off by using the same tire pressure in all seasons.
Old Feb 28, 2009 | 08:08 PM
Stkjock's Avatar
Stkjock
Retired Mod
40 is too much IMHO, your ride quality will suffer as well as your traction
IMHO - Listen to Norm - 32psi
Old Feb 28, 2009 | 09:05 PM
deekum1627's Avatar
deekum1627
i got 35 in now feels good so ill leave it for now
daltron
Apr 28, 2016 08:10 PM
Dokilar
15
Oct 16, 2015 08:13 PM
svfetter
Oct 5, 2015 11:39 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
1996cobraconvertible
SVT Forums
Sep 30, 2015 02:01 PM
