Panhard Problem?? ASAP!!
Old Feb 28, 2009 | 08:27 AM
  #21
pascal's Avatar
pascal
S197 Section Modder-ator
Originally Posted by Norm Peterson
It's very tight but possible (5'-11, 175-ish). Spike a couple of 2 x 10's together for each side and it gets a lot easier. One other thing - forget about using a normal creeper, there isn't that much room to spare so get out the cardboards.
Norm
Hey, some of us are skinny you now...
Old Feb 28, 2009 | 08:47 AM
  #22
JasperGT's Avatar
JasperGT
Originally Posted by MTAS
If anything on the bar was loose, you'd know it every time you went over a bump or rough set of RRX. The adjustment nut on mine loosened up (before I realized I didn't put blue LocTite on it) and it sounded like the back half of the car was gonna break off
My car felt the same exact way, until I put the blue LocTite on the car! I felt like the car was gonna break in half at any minute when driving on some rough roads. It's fixed now! YEAH!
Old Feb 28, 2009 | 08:51 AM
  #23
JasperGT's Avatar
JasperGT
I have the BMR adjustable panhard bar, and all I have to do is lie down next to the back tires and adjust it with a wrench. Simple as can be.
Old Feb 28, 2009 | 01:56 PM
  #24
157dB's Avatar
157dB
Cut & Paste Expert
Originally Posted by moosestang
You have to adjust the panhard bar with the full weight on the tires. If the drivers side is sticking out to far, then shorten the panhard bar.
+1 Adjust the panhard bar at ride height.
Old Feb 28, 2009 | 05:38 PM
  #25
Sixx's Avatar
Sixx
When I changed the Lower Control Arms I nailed a couple of 2 x 4's together. Lifted the car an extra 4 inches. There was just enough room to work. Easy access to the panhard also.
Gene K
Oct 21, 2015 11:37 PM
DJ Piner
Sep 30, 2015 03:03 PM
GimpyHSHS
Sep 18, 2015 12:27 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
RWHEELS
Sep 5, 2015 03:42 PM
