Hurst short throw problems.
Old Mar 2, 2009 | 08:35 PM
Bigcha40's Avatar
Bigcha40
i had some spray can chain wax i had left over from when i had my streetbike, sprayed some of that on the ball and i havent had a rattle since
Old Mar 3, 2009 | 05:49 PM
svtwin's Avatar
svtwin
I've got some chain lube in the garage...I'll have to try that
Old Mar 3, 2009 | 06:38 PM
Ato's Avatar
Ato
Under hard load at high rpms its going to rattle, doesn't mean there is anything wrong w/ it.
Old Mar 4, 2009 | 02:55 AM
07musclemustang's Avatar
07musclemustang
just sell it and get a pro 5.0 or mgw
Old Mar 4, 2009 | 05:38 AM
funtimesalways's Avatar
funtimesalways
deekum, you glad you went from hurst to mgw?
Old Mar 4, 2009 | 09:07 AM
Kotobuki's Avatar
Kotobuki
Allow me to assure you this is not the case. I can run it out to red line with the pedal on the floor and never hear a thing from it. Just a little lube to cushion the socket and it's silent as the stocker.
Old Mar 4, 2009 | 10:48 AM
Ato's Avatar
Ato
At 5000+ rpms even my stock one rattled or vibrated to some extent. Same goes w/ past aftermarket shifters I have put in other cars. When you replace flexible metal and mushy rubber w/ a more rigid metal design and a firmer urethane bushing its going to transmit more vibration and more road noise. Now I'm sure some shifters like mgw have found ways to isolate that, all I'm saying is that w/ the design of the Hurst its just going to be a factor. I knew this going into my purchase and I am fine w/ it since around town and cruising on the highway the shifter makes no more noise then stock, it's only at high rpms when I'm beating on it that the noise arises.
Old May 11, 2009 | 12:08 PM
harraid5711's Avatar
harraid5711
guys, before i go out and buy some break free, would white lithium grease work just as well?
Old May 11, 2009 | 02:14 PM
harraid5711
after lookin into it, i guess break-free is more of a liquid. would regular gun lubricant work? is break-free special?
Old May 11, 2009 | 02:44 PM
whtcanbrwnd04u's Avatar
whtcanbrwnd04u
https://mustangforums.com/forum/2005...ing-hurst.html
Post #3.
I haven't done this, yet. But i plan to when i get the time. Hope it helps...
