Hotrod Turned Commuter
Because of some recent changes in my life...Thank you California Budget Crisis....I will be commuting around 60 miles a day instead of my normal 1 mile round trip to work. My question goes out to all of those who have modded. What do you think is going to bump my gas mileage up. Right now i don't have anything on my car contrare to what my profile states.
I am thinking UD pulleys, Fully Synth fluids throughout, and beyond that i am stumped. I Know it comes down to the way you drive but i just want to know if any hyper-milers have any suggestions.
UDP's and a more fuel efficient tune could help.
I would call up VMP or Brenspeed and get a 87 octance "fuel efficient" tune.
Honestly that is really it. Try removing that lead foot and it will help lol.
Also any mods you can do to reduce weight will help too.
Sixty miles a day? That's nothing. Try 131 miles everyday - got 105K on a 2006 GT. I have tried just about everything to increase mileage (while not hurting performance of course) and speaking from experience here, getting rid of that last item in your signature is about the only thing that will have a big impact on your gas mileage. Well actually, looking back at your signature, I see you still have the stock mufflers - I noticed just over a mile per gallon increase after installing less restrictive after market mufflers (in my case the JBAs). Gained more after that with the headers, and then lost it all after the CAI/tune. Although, I have to admit, that after the CAI/tune I don't always drive for economy. I can shave 20+ minutes off of my commute by doing 80 instead of 60 and that is not so good for mileage. Sweet spot for my Mustang seems to be around 55MPH and 72MPH, between there, higher or lower and gas mileage goes down. But in the end, who cares? It's a Mustang GT, if I wanted great mileage, I would have bought a Prius.
Learn to anticipate situations ahead that would affect your speed. Learn to look a bit further down the road than just over the hood or at the bumper & brake lights of the car ahead. Move left in your lane a little so you can see past SUV's a little better. Driving by somebody else's brake lights is a recipe for having to brake harder than necessary.
A little higher tire inflation pressure may help a small amount, but don't go overboard with this like some of the hypermilers do. Making sure that they don't ever go low is at least half the battle.
Norm
Norm
One thing I missed is that getting away from such a short commute will put the engine in its fully warmed up condition. Most, if not all of your old commute was done with some warm-up enrichment happening. That suggests that estimating fuel usage for the new commute based on your experience with the old one will be skewed toward higher fuel use/lower MPG than what you'll actually get.
Norm
Norm
Put the intake back on, get it tuned for fuel efficiency, get some light weight wheels with low resistance tires(a.k.a tires with no grip lol) And drive behind semis and other LARGE vehicles. I got 36mpg in my stock '08 cruising behind an 18 wheeler at about 60-70 mph for about 100 miles. I also have 3.31 gears tho.
I think it was mythbuster that looked at if drafting really works at highway speeds and they found that at 80MPH you would have to be less than five feet behind a semi before you saw any noticeable gains in fuel economy. It can actually be worse on fuel because if you are more than five feet away you hit the trucks turbulence and probably a lot of rocks.
I drive mine everyday with periods of stop and go and the only thing that has helped is skip shifting when possible and staying out of it. I also find that by leaving a half hour earlier everyday I miss the stop and go and that saves a great deal.
Goodluck!
Goodluck!
Goodluck!
Goodluck!
