Terrible time with gear install
Old Mar 9, 2009 | 08:22 AM
joemagna's Avatar
joemagna
Thanks for the link DB157!
White07, I no longer call him friend. Needless to say, we arent anymore. I'm sending an email to the owners of the shop. See what happens...
Old Mar 9, 2009 | 10:05 AM
schapman's Avatar
schapman
same here...Gearheads in arlington tx did 2 installs and both had the pinion bearing come apart. needless to say i didnt go back a third time.
Old Mar 9, 2009 | 11:14 AM
doctorstrobe's Avatar
doctorstrobe
I wonder if they forgot to put the oil slinger back in?
It's just a thin washer that looks kind of like a shim. It goes in the front just behind
the seal. Without that the front bearing won't get oiled properly...
The axle housing itself should be fine.
All the bearing races can be easily replaced.
The other thing they might have done wrong is used an impact air gun to do do the bearing pre-load. If they put too much bearing pre-load in then it would probably make some pretty bad noises.
Old Mar 9, 2009 | 11:29 AM
schapman's Avatar
schapman
yea both install made noise from mile 1. I think it was the preload. Hopefully I will win my CC dispute and get a few hundred back. Gearheads lied and said i gave them used gears for the install also.
Old Mar 9, 2009 | 11:50 AM
05 Mustang's Avatar
05 Mustang
thanks for the suggestion doctorstrobe...as many times as Joe's car has been apart, it's hard to believe something like that would be missed, but it definitely sounds like something that could cause the problems that he's been having....besides not properly being set-up the first few times, it's always been something with the bearings..
Old Mar 9, 2009 | 03:47 PM
hypersurf1's Avatar
hypersurf1
First, the guys at goodyear are good at tires and basic parts changing. I know, I spent 8years running goodyear stores. No highly qualified technician would work for what we were paying. That said...
Nothing short of a botched gear install would give you the problems you are having. I have never allowed for a break in period and beat my gears from day one on many mustangs I've owned with zero problems. Setting up 8.8 ring and pinions is an art and if you havent done alot of them you are going to screw it up unless you have someone who has done them showing you how. Tell this clown you want your money back and go somewhere that has alot of experience with mustangs doing your differential. Do not let him touch your car again other then for a set of tires or an alignment.
Old Mar 10, 2009 | 07:35 AM
joemagna's Avatar
joemagna
Thank you for this post. Very well said. Hindsight is 20/20 and I was a noob when it came to cars and aftermarket parts. BTW, I wouldnt let him even change my tires in the future. His guys will strip the studs...right cameron???
Old Mar 10, 2009 | 08:17 AM
Hicompression's Avatar
Hicompression
So who lied about the used gears? Chris or Travis? Back when I had my '90 GT, I had GearHeads put 3.73's in it. I never had a problem with it. This was back before they hired Chris as the counter guy. A guy by the name of Scott put my gears in. They've got someone different doing it now.
I can't say your story suprises me. It seems nowadays they are more interested in "quantity" than "quality".
djbigskrilla
Sep 20, 2022 01:04 AM
drfister
May 3, 2018 10:38 PM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
cema93
Aug 10, 2015 09:35 PM
