"Gut Check" on 4.10's
Old Mar 7, 2009 | 02:37 PM
S197winstang's Avatar
S197winstang
Go with 3.73- it is the best all around set-up. if you hate it switch to 4.10, gears are not a all or nothing mod..
Old Mar 7, 2009 | 02:47 PM
S197winstang
Thumbs up
Originally Posted by vaporstang
From reading up on MF, if you have an automatic, you don't want to go above 3.73s.
On a manual, going from 3.55s to 3.73s is not worth it - I assume going from 3.31s to 3.73s would be. Someone chime in if I'm wrong....
You are correct.
Old Mar 7, 2009 | 07:03 PM
VistaGT's Avatar
VistaGT
Dude 4.10s are nasty! The only problem is lack of traction!!!!
Old Mar 7, 2009 | 07:16 PM
vaporstang's Avatar
vaporstang
Thanks everyone for your responses - it's a great help! I meant to get out to the dealership this morning for estimates, but ended up doing my taxes.
As stated earlier, I believe my dealership knows what they are doing. However, when I ask for the estimate, I'm not mentioning new bearings just to see if they recommend them or automatically include them. If they don't, I'll start looking for a different shop. (I know it ain't much of a test.) I'll also be asking about the no-whine guarantee also.
Old Mar 7, 2009 | 07:19 PM
vaporstang's Avatar
vaporstang
Are you saying I need different tires and/or suspension mods?
Old Mar 7, 2009 | 07:27 PM
kpaulhus's Avatar
kpaulhus
I am happy to see the post about the 28" tires....I just had mine installed today and my 4.10's are going in in 2 weeks to make up for the extra tire weight.
Old Mar 7, 2009 | 07:32 PM
Stkjock's Avatar
Stkjock
Retired Mod
IMO (i have them) the only issue with 4.10s is if you do a lot of long highway driving you pull a lot of RPM @ 75, a 28" tire will kill some of the effect
Old Mar 7, 2009 | 07:49 PM
moosestang's Avatar
moosestang
According to an Excel spredsheet gear calculator I got on MF, the redline speed for 4.10s on a manual w/ 235/50R18 tires is 184mph.
(I can't get the file to attach and I don't remember if he had set up a link....)
It's closer to 199mph and that's at the stock rev limiter of 6250.
http://www.angelfire.com/fl/procrastination/rear.html
Old Mar 7, 2009 | 08:36 PM
vaporstang's Avatar
vaporstang
You got me off on a rabbit trail! What gear ratio are you using for 5th gear - .62? I've seen the spec before, but can't remember it. My spreadsheet has .68
Old Mar 7, 2009 | 10:04 PM
bri69wal's Avatar
bri69wal
Default tire size calculator
here is a link to tire size diameter that you can put in different size tires.
http://www.tacomaworld.com/forum/tirecalc.php
mtgldr
Feb 3, 2024 09:00 PM
junior04
Sep 28, 2015 10:53 AM
stealth_GT
The Racers Bench
Sep 22, 2015 02:19 PM
panic
Aug 28, 2015 02:37 AM
