loctite question
Old Mar 9, 2009 | 06:18 PM
chain_rxn's Avatar
chain_rxn
Default loctite question
a question for u glue guru's. my new shift ball needs a dab of glue to secure it so that the shift pattern is facing the right direction. what loctite color should i use? i want it on tight, but not so tight that i can remove it if i need to.
Old Mar 9, 2009 | 06:26 PM
Burnsy's Avatar
Burnsy
blue will work
just don't put it on your oil drain plug
Old Mar 9, 2009 | 06:36 PM
zporta's Avatar
zporta
just dont use red...
Old Mar 9, 2009 | 06:37 PM
MELLOWYELLOW06's Avatar
MELLOWYELLOW06
blue only
absolutely no red
Old Mar 10, 2009 | 07:56 AM
chain_rxn's Avatar
chain_rxn
mucho gracias!!!
Old Mar 10, 2009 | 04:22 PM
157dB's Avatar
157dB
Cut & Paste Expert
Originally Posted by Burnsy
blue will work
LocTite 242 (blue)
Its an anarobic adhesive that sets up in the absence of air and
the presence of metal.
Be sure all threads are super clean or it wont set up properly.
A jam nut with the proper threads is the right way to keep the
shift **** from spinning and becoming unindexed.
https://mustangforums.com/forum/2005...rain-plug.html
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
