Lowering/Suspension
Old Mar 10, 2009 | 08:53 AM
lbballin9's Avatar
lbballin9
Default Lowering/Suspension
I have Billet LCA's on my car right now, and I am wondering whether I should get a lowering kit. I have a couple questions for it though. The one I'm looking at will lower the rear 1" and the front .75" Since I already have the lca's, will I need to be a relocation bracket, or will I have to buy adjustable uca's? Or can I just put the springs on with nothing else and it won't affect what my lca's are already doing? Thanks!
Old Mar 10, 2009 | 11:36 AM
ICIBUY's Avatar
ICIBUY
Hopefully Sam Strano will chime in on this... I have an 05 GT and here is what Im running.. Ebiach pro kit, Koni's, upper Steeda HD strut mounts, adjustable pan hard bar. Lowered the front a little over an inch and the back almost an inch and a half. Car handles great, doesnt ride much stiffer than the stock set up and no more wheel hop! I didnt do anything with LCA's or UCA's and Im happy with this set up however I dont race my car. Good luck!
Old Mar 10, 2009 | 01:13 PM
AmericanSpeed's Avatar
AmericanSpeed
With a mild drop, you can prob get by without having to adjust pinion angle, but it would be better to get an adjustable UCA to correct the angle (adj LCAs work too, but since you already have aftermarket non-adj LCAs, you can go with the adj UCA). I don't think relocaton brackets are necessary. You may want to get an adj panhard rod though, lowering will cause the rear end to shift to one side. Though the shifting won't be too dramatic with the mild drop, you might not need it depends on how your rear end is aligned from the factory.
Old Mar 10, 2009 | 02:00 PM
ffk_pennywise's Avatar
ffk_pennywise
I lowered mine a few days ago and didnt need the adjustable panhard. I do need upper strut mounts though. I made it a whole 35 miles before the passenger side went to crap. I just ordered the SVT mounts. Hope they work better!
Old Mar 10, 2009 | 03:35 PM
lbballin9's Avatar
lbballin9
So what do you guys think about BMR's for 125? Go for it? I'll definitely be getting some adjustable UCA's
Old Mar 10, 2009 | 04:47 PM
AmericanSpeed
You sure you don't need to just tightent the front sway bar end link bolt that attaches to the strut? After lowering my car, that SOB comes loose every couple of monthes and makes clunking noise like crazy until I tighten it.
Old Mar 10, 2009 | 05:07 PM
zporta's Avatar
zporta
i have heard that BMR doesnt have the best bushings... but thats just from a few ppl
Old Mar 10, 2009 | 06:16 PM
ffk_pennywise
No, I'm not sure. But I did tighten the crap out of it. And the it doesnt rattle or anything. It just pops when i make turns.
Old Mar 10, 2009 | 07:45 PM
owero01's Avatar
owero01
You won't need the relocation brackets. If anything, you will need an adjustable UCA to set the pinion angle. Maybe and just maybe an adjustable panhard bar.
