Odered Aeroforce Tech Gauges! -- Can't Find 4.10 Shop
Last night I ordered Dual Aeroforce gauges from Aeroforce along with 2 Roush vent pods from Brenspeed!!! I didn't know whether or not to go with the SOS dual pillar pod or the vent pods. I figured the vent pods would be more low key and less likely to bake in the sun (don't know if that is an issue or not). I just need to decide if I want to go with the two driverside vents or the two center vents. Leaning towards the two driverside vents.
I'm still having trouble finding a shop that seems experienced in and is willing to install 4.10 gears. It's hard finding time to spend, even at lunch, searching. The one shop that seemed to know what they were doing was in the process of moving and didn't want to mess with it for a couple of weeks (I don't think they wanted to do it at all). I'll keep searching. I'd rather keep the 3.55s instead of risking the install with someone I don't trust.
Thanks...that's about 2-1/2 hours away. I actually checked Brenspeed's location; it's almost 5 hours. If I'm going to travel that far (2-1/2 or 5 hrs) and have to wait, I might as well make it worth my while and get an aluminum DS also!
Go with the two center vents. I have an Aeroforce tech gauge mounted on the drivers side vent. It's somewhat difficult to read when the sunlight hits it.
I only have one, so it would look a little funny in the center, however, if I had two, then I'd probably mount both in the middle. It seems like the glare would be less in the center of the dash.
Don't forget a paxton and blower cams as well. Might as well.
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
