Brake install help!!
Old Mar 11, 2009 | 07:34 PM
Smooth_J's Avatar
Smooth_J
Default Brake install help!!
All, please help I never really done this before, so please....help!!!!
I received the GT500 used calibers and so I wanted to install the J&M SS lines. However when taking the old lines off and trying to put the new lines on I noticed I can't get the copper washer off the screw (on both calibers). Do I just need to get new washers/screws?
If that is the case, which ones do I get??
Please, please let me know.
Thank you!!!!!!!
Old Mar 11, 2009 | 08:11 PM
charliebrown266's Avatar
charliebrown266
Just hold the bolt in your hand and tap it with hammer or screw driver,the crush washer will come off,you should replace them though.
Old Mar 11, 2009 | 08:14 PM
Smooth_J's Avatar
Smooth_J
Where can I get replacements from exactly and what size banjo bolt is needed?
Old Mar 11, 2009 | 08:21 PM
charliebrown266
you should be able to use the old banjo bolts and just replace the crush washers,you should be able to buy them at any auto part stores.just bring the old one to get the right size.
Old Mar 11, 2009 | 08:46 PM
Smooth_J's Avatar
Smooth_J
The old ones appear to be a bit smaller than the bolt - is that normal?
Old Mar 12, 2009 | 12:13 AM
Smooth_J's Avatar
Smooth_J
After looking I think I know the size of the washer. It gave me a scare since I thought I had all the parts. Thank goodness you can reuse quite a few bolts and etc from the stock parts.
Old Mar 12, 2009 | 12:26 AM
MELLOWYELLOW06's Avatar
MELLOWYELLOW06
I used the standard lines on mine. You guys think its a good upgade to go to the SS lines? How much and where?
Old Mar 12, 2009 | 12:42 AM
Smooth_J's Avatar
Smooth_J
Its supposed to give you more a a "firmer" brake pedal feel, and besides I was doing the brakes and I figure why not - I still need to do the bleeding. Some say do it, other say no need to.
I picked the J&M lines from American Muscle and it was shipped to me that night and I received it next day
On another note, what size washer is required? I thought I found it, but I think I'm off a bit...
EDIT: Here is some report if you want to read it: http://www.goodridge.net/usa/pdf/all...s_v_rubber.pdf
Old Mar 12, 2009 | 10:24 PM
Smooth_J's Avatar
Smooth_J
Well, I found out what washers were needed. I asked tituswillfordparts and they said EOAZ-2149-B. Just a FYI to all.
They are $0.77 cents each each :/
Granatelli Sales
Jan 20, 2020 12:34 AM
TimeLord101
Sep 4, 2015 09:27 AM
Luke9222
Sep 4, 2015 06:46 AM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
