Someone tell me whats wrong with this picture....Dyno sheet inside.
Its wrong but the dyno was not calibrated right either. Also take into consideration that the humidity and the heat are also a big factor.... I figured about 280+ HP to the rear wheels.....GT's come from the factory at 260 give or take...mine was 270 stock
YEAH fo sho the dyno is off i dynod 293 today on a dyno jet...ive had bad experinces before today the last dyno i was on said i made 326 rwhp i think the dumb *** ppl dont know exactly what there doing...btw my guy today did the pulls in 3rd? My last guy did them in 4th which is it suppose to be?
LOL - I think this might actually be a problem I ran into at a local shop when I went in to use their Dyno to make some pulls prior to installing my cams. It is especially prevalent in shops who deal a lot with imports. They may have actually made the pull in 3rd gear. Go check with them and ask them what gear they used (unless you made the pull yourself). That being said, a Dyno can be made to say anything (as I learned when a local shop showed me a dyno graph showing a Flowmaster A/B system that "made" 28HP at the wheels on an S197).
HTH
~Matty
HTH
~Matty
