Thinking about a Weekend Project - Hurst Shifter
Old Mar 20, 2009 | 09:41 AM
jvecero3's Avatar
jvecero3
Default Thinking about a Weekend Project - Hurst Shifter
Hey Everyone -
I'm thinking about getting this:
http://www.parts123.com/parts123/yb....Z5Z5Z50000016b
But, I have a few questions: Is this the shifter that some have stated has a rattle to it? How bad is the rattle? Is it worth it?
Next question is about the installation...Has anyone done this installation themselves? How is the installation done and how easy is it? I'm no mechanic, but I'm somewhat mechanically inclined. I can use tools, but then again, so can most monkeys. Think of your average guy and would he be able to do it, or would he be better off just letting a professional do it?
Thanks All.
Old Mar 20, 2009 | 09:54 AM
abrush's Avatar
abrush
I have that exact shifter and did the install myself. Personally I didn't think the install was bad at all. I think the hardest part was manuevering the shifter to make it go through the hole in the floor from inside the cabin. Otherwise it is a pretty straight foward install.
On the rattling, I have had no problems with mine. Although several others have reported rattling after the install.
Old Mar 20, 2009 | 10:13 AM
jvecero3's Avatar
jvecero3
Thanks for the response.
Also....Everything mechanically on my car s stock. I'm assuming that that's not an issue, and that I can just switch out the shifter without running into anything else I would need to buy or change.
Old Mar 20, 2009 | 10:28 AM
acascianelli's Avatar
acascianelli
Originally Posted by jvecero3
Hey Everyone -
Thanks All.
The installation was easy. This was the first mod I installed on my car. I was able to do it with a set of ramps. You won't have a problem with rattling, just make sure you tighten the bolts good and maybe use locktite. It took me about 45 minutes.
Old Mar 20, 2009 | 10:46 AM
SC55509's Avatar
SC55509
I have been in and around my 5 speed many a times and installed a shorty on mine as well although it was a steeda not a hurst but install was rather banine and I managed to do it myself
Old Mar 20, 2009 | 12:17 PM
Ato's Avatar
Ato
The install if very easy to do w/ basic hand tools although it can beat up your hands in the process since the space you are working in is very tight. On the rattle, mine really hasn't been a problem, but from what I've heard it's usually the v6s that have the issues. There is a fix someone has come up w/ that is very easy to do while you are under the car to solve the problem, it involves adding a rubber tube as a spacer to take out the slack in the shifter. If you do a search you'll find it np.
Old Mar 20, 2009 | 12:25 PM
Tracedaddy's Avatar
Tracedaddy
I installed mine ini a couple hours. It could've been quicker but I didn't have a deep socket in the right size (I think it was 11mm but don't quote me.) I also needed to get a wratcheting wrench. It is tight quarters and like abrush said, the tough part was manuevering the thing through the hole.
I have had no rattles whatsoever. Make sure to use threadlock.
Old Mar 20, 2009 | 12:27 PM
jvecero3's Avatar
jvecero3
Awesome responses as always, guys. I appreciate all of your time and help. Feel free to keep 'em comin'!
One other question....I've got a couple of jack stands, so I have the option of putting up the front of the car, or the side. Can anyone suggest if one would be a better way to approach it than another?
Old Mar 20, 2009 | 12:36 PM
Tracedaddy's Avatar
Tracedaddy
I guess it depends on how tall your stands are. Mine, I think, are typical and I just jacked up both front wheels. I would've been afraid of rolling the thing over if I'd tried one side or the other. It's probably misplaced, it would probably need to go a lot higher to actually roll, it would've just felt odd I think. I had enough room underneath by jacking up the front.
Old Mar 20, 2009 | 01:06 PM
deekum1627's Avatar
deekum1627
i just used ramps and had plenty of room you can do it yourself its really easy
