Door panels
Old Mar 27, 2009 | 10:30 PM
JamesNorman's Avatar
JamesNorman
Default Door panels
Does anyone know where I can get the interior door panels for a 2005 GT? I have the tan interior, but I want to replace the piece that surrounds the armrest with black inserts.
Old Mar 27, 2009 | 10:47 PM
wilkinda's Avatar
wilkinda
2010 Section Moderator
like this look??
Old Mar 28, 2009 | 03:20 AM
VictoriaRR's Avatar
VictoriaRR
Wait... what armrests?
Old Mar 28, 2009 | 10:14 AM
mxg30's Avatar
mxg30
The part your referring to is not a solid piece in that you can replace it as though it is an insert. (follow me).The insert is simply leather (vinyl) that is applied with adhesive like you would a headliner and is tucked in around the edges.I know this because mine on both sides stared to peel off and I had to re-attach them (not too difficult but time consuming).You would have to peel off the old and re-attach the new material (and you canNot use spray adhesive unless you are very accurate)Your best bet would be to find the entire door panels the way you want it from a donor car or if your not up to the task take it to an upolsterer.One other option is that you could peel off the old, scrape and clean off all of the foam backing and paint.
jerrytubes
Oct 23, 2015 12:11 PM
b8checker
Oct 8, 2015 12:55 PM
jrrhd73must
Oct 2, 2015 09:17 PM
b8checker
Sep 30, 2015 07:11 AM
