MGW Shifter Post Install...QUESTIONs
Old Mar 29, 2009 | 08:49 PM
Rskapof's Avatar
Rskapof
Default MGW Shifter Post Install...QUESTIONs
I just installed the shifter. Fairly easy.
I am noticing that in the higher gears the shifter shakes more than in the lower gears. When i get it into fourth gear the shifter has a slight shake to it as opposed to first or second.
I have the shifter turned 9 out of 10 times for the shortest throw. Is this to be expected or should I start troubleshooting?
Old Mar 30, 2009 | 08:51 PM
vasman's Avatar
vasman
I just installed mine last weekend at 6 turns. No vibration at all. Only vibration when I pull on the gear without clutching (such as when on 5th gear resting your hand on the shifter and pull it a bit towards the aft of the car). I am planing to go down to 8 turns next weekend to make the throw a bit shorter. I will let you know if I notice any additional vibration. One of the things I read on another install when car lowered and the pinion angle is not adjusted properly, there is a chance mgw is rubbing on the axle over 8 turns or so. Check it out.
firehorse02
Nov 16, 2015 11:28 AM
Explosive
Oct 2, 2015 07:45 AM
guitarman376
Sep 30, 2015 05:54 PM
CS2007
Florida Regional Chapter
Sep 29, 2015 12:06 PM
junior04
Sep 28, 2015 10:53 AM
