D-spec problem adjusting
Old Mar 30, 2009 | 08:46 PM
schapman's Avatar
schapman
Default D-spec problem adjusting
I can adjust one of my front D-specs. anyone have any ideas why it wont turn?
Old Mar 30, 2009 | 10:40 PM
owero01's Avatar
owero01
Never had a problem adjusting them. I assuming you can't turn it either way, so you may have a bad one.
Old Mar 31, 2009 | 12:41 AM
rshamekh's Avatar
rshamekh
I have the same problem.
Mine turn but no resistance so I know they are not adjusting anything. Haven't found a fix yet.
The rear shocks are fine.
Old Apr 7, 2009 | 11:38 PM
rshamekh's Avatar
rshamekh
Bump. Anyone?
Old Apr 8, 2009 | 12:35 AM
Ato's Avatar
Ato
The question is did they ever turn to begin with, you didn't put an impact gun on the top when installing did you?
Old Apr 8, 2009 | 07:58 AM
Simon1's Avatar
Simon1
They don't offer resistance while adjusting to loose. It's the same tension from 1/2 turn to 7.5 turns. I only felt resistance when I went to full tight.
Try tightening them up and see what happens.
Old Apr 8, 2009 | 08:45 AM
rshamekh's Avatar
rshamekh
I tried going full tight to see if it stops but it doesn't!
They were installed by the ford dealership here (biggest mistake, I know!).
If they happened to use an impact gun, would they have broken something?
Can I still take it off and put it back on and it would still work?
Old Apr 8, 2009 | 08:57 AM
Ato's Avatar
Ato
I bet they did put a gun on it and just f'ed up the guts of the struts.
Old Apr 8, 2009 | 09:10 AM
rshamekh's Avatar
rshamekh
But I can adjust the rear shocks just fine, wouldn't they have used an impact gun on that too?
jma2
Jul 10, 2023 01:00 AM
Sminemann
Sep 17, 2015 09:24 AM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
DoctorScary
Sep 9, 2015 07:53 AM
RWHEELS
Sep 5, 2015 03:42 PM
