Sponsored by:
Sponsored by:
Reboot the CPU in an 07's GT?
Old 04-17-2009, 09:21 PM
stangboy555
stangboy555's Avatar
It was just the fog lights, I guess I didn't turn the switch far enough when I got out.
stangboy555 is offline
Old 04-17-2009, 09:29 PM
Stoenr
Stoenr's Avatar
That's even more weird. They wont go on unless the key is on.
Stoenr is offline
Old 04-17-2009, 10:05 PM
stangboy555
You know what. I think you're right. I'll have to check that.
But I do clearly remember opening the car door and only seeing the switch at the parking/fog position.
Old 04-18-2009, 12:15 AM
White05GT
White05GT's Avatar
Didn't the beeper thing go off that tells you your lights are on when you open the door?
White05GT is offline
Old 04-18-2009, 10:05 AM
157dB
Cut & Paste Expert
157dB's Avatar
Originally Posted by stangboy555
So last night I left my lights on at Hooters, I was notified pretty quick by some buddies who came up after me and I turned them off after about an hour or so. The car started fine and I didn't have any problems at all.
Well, about and hour later while driving the car all of the Check engine, Traction control and every other damn warning light came on, also my Tach and Speedometer took a dump and went flat, along with the Temp gauge.
Sounds like the dreaded underdash water dispensor option none
of us ordered but go anyway. The SJB probably has been getting
wet everytime it rains and the water has started the corrosion
process and the system is goind haywire....
My 07 will turn the headlights on whenever it want to independent
of the ignition key position. They automatically shut off 15 minutes
after the last door is closed and the key is off.
Yes it does and if the fogs were on, you can bet the running lights
were on as well as there is a mechanical interlock in the headlight
switch that prevents you from turning off the clearance lights
without the fog switch in.
157dB is offline
Old 04-18-2009, 10:15 AM
Stoenr
Stoenr's Avatar
You are correct sir, but I was referring to the fog/driving lamps
Stoenr is offline
Old 04-18-2009, 11:22 AM
Orion_240
Orion_240's Avatar
don't forget that some states/ countries have daytime running lights. Just to complicate things even more.
I wonder if the battery maker's lobby got Ford to not put in a device to automatically turn off our headlights after a few minutes!
Would a new battery help the OP?
Orion_240 is offline
Old 04-20-2009, 06:33 AM
stangboy555
I'll find out whats up in a couple hours. going to take the car to the dealership as soon as I can find a ride home :-)
Old 04-20-2009, 02:34 PM
stangboy555
So it was a loose connector somewhere. Mechanic found it while poking around, said they reseated it and it's fine now. I'll get the details when I pick up the car in the morning.
They're keeping it overnight to wait for and replace the ebrake assembly that broke a few weeks back.
Old 04-21-2009, 08:36 PM
stangboy555
So I went to pick up the car today, as soon as I jumped in and started the car it did the SAME thing.
Jackasses. They plugged the loose connector back in but didn't bother to make sure everything was working on both ends. Guy made up a bunch of excuses and then ordered a whole new junction box. That's the box on the lower right passenger side foot panel.
I'm pissed, no Stang in 2 days makes me grumpy.
Quick Reply: Reboot the CPU in an 07's GT?
