Drivers Door Window
Old May 8, 2009 | 10:15 PM
Newps's Avatar
Newps
Default Drivers Door Window
On my 05 Convertible if I hit the drivers window up switch so it closes automatically it runs the window all the way up and then all the way back down. The passenger window works like it should. Any ideas what causes this?
Old May 8, 2009 | 10:38 PM
fakesnake's Avatar
fakesnake
Could be:
1) Bad switch
2) Fault in the convertible top switch
3) Water leak behind passenger kick panel shorting fuse panel
4) Humidity causing shorts
It has happened to me a few times but has now gone away
Old May 8, 2009 | 10:45 PM
graystanggt's Avatar
graystanggt
Im kinda curious about this too. My driver side window has done this a few times too.
Old May 8, 2009 | 11:12 PM
cegha's Avatar
cegha
TBH i believe this is some glitch in the window wiring. i have a 08 GT, and have had this happen on occasion. I don't believe i've ever had it happen to the passengers side as stated.
Sometimes randomly like when rolling up it will proceed all the way up, or partly up, then roll back down. As said i think it's just some small glitch that happens if things get pressed a certain way.
It has never been a persistent problem however. Probably happened 3-5 times in approx the year and couple months i owned my car. It was bought brand new as well.
Would be great if anyone that's had this happen would post how many times, and the frequency. Also would like to hear from anyone if they've had it persist.
Old May 9, 2009 | 02:56 PM
157dB's Avatar
157dB
Cut & Paste Expert
Re-Calibrate the window on the drivers side.
Its all in the Owners Manual. Page 46.
If that dont fix it, its the overcurrent detection
(to keep you from rolling your hand up into the
window) that is out of whack and the whole
window motor needs to be replaced.
Bounce-Back Protection. Recalibrate with
top up and doors closed as per the Owners
Manual directions.
Its not a wet SJB because all the motor logic
controls are all in the motors themselves.
Old May 9, 2009 | 04:59 PM
Orion_240's Avatar
Orion_240
any idea why the side rear windows in Verts don't have the auto down/up feature?
Old May 10, 2009 | 06:04 PM
Luxembourger's Avatar
Luxembourger
May be this:
http://francesco.maxdsl.de/documents...B/08-21-07.pdf
cr620
Oct 3, 2022 10:18 PM
b8checker
Oct 8, 2015 12:55 PM
b8checker
Sep 30, 2015 07:11 AM
Sixer4Life
Sep 29, 2015 07:03 PM
Sep 25, 2015 06:58 PM
