Sponsored by:
Sponsored by:
Solutions for throttle lag?
Old 05-13-2009, 02:24 AM
Shadow7874
Shadow7874's Avatar
Default Solutions for throttle lag?
I hate that i can drop my clutch from 2k or so and have to wait a sec for it to get going. Will a tuner speed that time up? if so how much really? Theres one for $200 shipped in the s197 classifieds and he lives an hour from me so i could just pick it up.
Shadow7874 is offline
Old 05-13-2009, 03:11 AM
domindart
domindart's Avatar
Luv ur avy
What did u do to your antenna, cut it?
What is a tuner?
domindart is offline
Old 05-13-2009, 03:21 AM
abarker8541
abarker8541's Avatar
a blower will solve that! A cai and good tune will do u a little bit of good
abarker8541 is offline
Old 05-13-2009, 03:27 AM
Shadow7874
Shadow7874's Avatar
When i see a blower for $200 i will be sure to jump on it!
Would just the tuner help is what i want to know.
I plan on modding my car slowly, so if i get a tuner now will i need to spend money on a new tune for each mod?
Originally Posted by domindart
Luv ur avy
What is a tuner?
Pulled off the ball, cut the antenna even with the roof, filed it a bit so the ball would fit back on, superglued the ball back, shot it with black spray paint to cover a few scratches.
Tuner is hardware that loads software into your ecu that controls how your car operates. Allows you to adjust things so you can make gains from mods.
Old 05-13-2009, 03:29 AM
BleedinBlue
BleedinBlue's Avatar
Luv ur avy
What is a tuner?
Strong post
A tuner is a hand-held electronic device that plugs into the car's computer. The tuner can, in the hands of someone that knows what they are doing, change the computer's settings. It is used to optimize the car's power after modifications and to squeeze out a few more HP.
It is the modern version of a "Speed chip" that you may have heard of a few years ago.
And to the OP: Yes, a CAI and tune will greatly improve the typical lag problem. I'm not sure if a tuner alone will do so...
BleedinBlue is offline
Old 05-13-2009, 05:35 AM
abarker8541
its better to do cai and tune
Old 05-13-2009, 07:03 AM
Norm Peterson
Norm Peterson's Avatar
How about starting with the cheap and simple things - like the throttle reset procedure.
Norm
Norm Peterson is offline
Old 05-13-2009, 07:28 AM
Nuke
Nuke's Avatar
A used handheld tuner alone is not your answer since any tunes in it will not work on your car unless specifically written for your cars PCM. You'll have to buy new tunes to dowload onto the tuner. The functions that resolve throttle lag are not user-adjustable. The vendor that writes your tune can make those adjustments.
And if you're going the route of getting a tune, do it right and get a CAI & tune combo.
+1 on Norm's suggestion. I'll try to find and post the link to the thread for that. I believe there's a recalibration procedure which does not involve disassembly plus a thread on making a physical adjustment.
Nuke is offline
Old 05-13-2009, 08:27 AM
Nuke
Nuke's Avatar
Here's the recal procedure (cut & paste from another section)...
"Turn the key to ON (DO NOT START THE CAR!) and wait till all the normal lights in the dash go out, then slowly press the gas pedal until it is floored and release. Turn the key off, wait about 6 seconds and then start your car. Give it a try.
This will reset the throttle body settings and give the car a crisper feel. This is not a permanent fix but does help out every so often. Also unplugging you negative battery cable for 15 minutes will reset some settings but is not recommend unless you know what you are doing."
I believe the time to leave the battery cable disconnected is 20 minutes per a previous post by 157db. This resets the adaptive learning.
Nuke is offline
Old 05-13-2009, 09:24 AM
vashthe3rd
vashthe3rd's Avatar
mods.
A tune increased my throttle response, the car felt very crisp and on edge after I loaded up the boxed tune. *IGNORE WHAT WAS HERE FOLLOW WHAT NUKE SAID FOR THROTTLE POSITION RESET!*
and if you have an automatic it will help there too.
and what do you know...I have a tuner and a CAI for sale!
(C&L + predator combo if you're interested, had to make a plug )
vashthe3rd is offline
Quick Reply: Solutions for throttle lag?
