p0161 code???
Old May 15, 2009 | 05:02 PM
tombohum's Avatar
tombohum
Default p0161 code???
So the time has come to take my car in for emissions.I put the stock airbox back on and reset the tune to stock, I noticed the check engine light was on so I reset it.
When I went to DEQ I passed all the tests but they said since the computer has recently been reset I need to put at least 50 miles on the car then go back. The problem is that if I turn the car off the check engine light comes back on.
Does anyone know if I can pass emissions if the check engine light is on, if not how do I clear that code for good?
Old May 15, 2009 | 05:10 PM
Texotic's Avatar
Texotic
Don't know... sounds like you need to reset it and go for a 50 mile drive...
Old May 15, 2009 | 05:12 PM
tombohum's Avatar
tombohum
Yeah, that's what I was thinking
Old May 15, 2009 | 05:52 PM
tombohum's Avatar
tombohum
Does anyone know if the light/code will stay cleared if I clear it and then drive 50 miles?
tombohum's Avatar
tombohum
........or will I at least be able to pass the DEQ test even if the light is on?
Old May 15, 2009 | 08:53 PM
Art161's Avatar
Art161
Wouldn't it be better to repair/replace whatever is wrong with the O2 sensor circuitry?
Old May 15, 2009 | 09:15 PM
tombohum's Avatar
tombohum
That's the thing, I don't know what it is.
Old May 16, 2009 | 02:07 AM
Art161's Avatar
Art161
Well, I don't know what you need to do either.
I looked up the diagnostic trouble code and it says O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2).
If you're interested in fixing the problem rather than simply trying to get the MIL light to turn off, maybe someone more technically oriented can chime in.
If the light is on, you will not pass an emissions test in most states. Also, you often have to drive the car a certain number of miles after clearing a code or disconnecting the battery, before the car is ready for an emissions test. If the emissions test equipment shows that the car is not ready to be tested, you need to drive it some more. By then the MIL light will probably be back on.
Old May 16, 2009 | 07:48 PM
tombohum's Avatar
tombohum
Anyone else know what that code means?
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
ChampInSD
Oct 2, 2015 04:55 AM
