rough ride need help
Old Jun 10, 2009 | 09:31 PM
gabe23's Avatar
gabe23
Unhappy rough ride need help
i got some lowering springs for my 05 mustang gt and lowered it 2'' front and rear and the ride is rough is there some thing i can do to make it better ????
Old Jun 11, 2009 | 07:02 AM
05 Mustang's Avatar
05 Mustang
...did you also replace the shocks & struts?..if not, that should help some, but in the end your car's ride isn't going to improve too much with that amount of drop...
Old Jun 11, 2009 | 07:51 AM
Obsequious1's Avatar
Obsequious1
WELCOME TO MF'S
Check out the 05-2010 mustang section.
Old Jun 11, 2009 | 01:33 PM
chub46's Avatar
chub46
Try the LCA relocation bracket and LCA's. Mine road rough with the Steeda sport springs until I add the BMR LCA relocation bracket and the BMR LCA's. Now the ride feels almost like stock. My wife even felt the difference. Do both at the same time. I added the brackets first and it still road rough, because the stock LCA's will only fit in the bottom hole of the relocation bracket. The bottom hole of the relocation bracket did not place the LCA in the proper angle for a comfortable ride. Now that I have the BMR LCA's installed and I have them at the right angle the ride is much better.
Old Jun 11, 2009 | 02:12 PM
tx_zstang's Avatar
tx_zstang
You could be running into the issue with the rear bumpstops bottoming out, too. That will make a for a harsher ride indeed.
Old Jun 11, 2009 | 02:29 PM
Red Beast's Avatar
Red Beast
with that kinda drop it wont get to much better, what kinda wheels are you running? 16's? 17's? 18's? or 20's?
Old Jun 11, 2009 | 02:46 PM
degeze's Avatar
degeze
Do you have quality springs? and shocks/struts designed for lowered applications will definitely help.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
1Bad71
Sep 30, 2015 07:37 PM
Sep 27, 2015 03:16 PM
