Can't put gas in the tank on 08 GT?
Suddenly several weeks ago my 08 GT started acting like it was full when i tried to fill the tank! I originally thought the gas pump nozzle was messed up!! Nope!! Then i thought maybe a vent line got pinched when my engine mounts and blower were installed..Nope. Brenspeed said Ford has a TSB out on a filler neck/hose issue. Two dealers told me today that they have NO idea what i'm talking about??? I have to dribble a penney-nickel at a time!! Took 15 minutes for 8 gallons of gas! Anyone have this problem? Do you have a TSB ## or remidy...etc??? Thanks alot,Joe
I've had 2 different '06 models. One was a V6, and now I have my GT. I experienced this problem with both models. There's no predictability to it either. I only use a few different gas stations and pumps routinely and sometimes that work right, sometimes they don't. It gets very frustrating when you can only pump cents at a time and you're on empty trying to get to work on time, lol. But yeah I've experienced it off and on for the last 3 years, but it isn't consistent so I haven't tried getting anything fixed. I just know that if it isn't filling correctly when I start then I stop and go to a different pump immediately instead of trying to make it work.
I sometimes have trouble with my '06, and it's a fairly well known problem that's been documented on the various forums including this one. I have found that it's usually a particular pump that causes the issue, and I actually try to remember which pumps cause me the least amount of trouble. Some pumps I can go full blast with no issues and it cuts off just when it should, and I try to stick to those.
There are a few threads already started on this, here's a couple:
https://mustangforums.com/forum/2005...ns-please.html
https://mustangforums.com/forum/2005...g-problem.html
