Anyone used these?
Old Jul 3, 2009 | 10:34 AM
thewarmachine's Avatar
thewarmachine
Default Anyone used these?
02 Sensor Raiser Non Fouler Mustang 05+ from Brenspeed
I'm getting a code for a possible bad cat. Anyone think these will work to fix my code? I can't imagine that my cat is bad already. (Bassani high-flow cat with probably 5,000 miles run on it)
Old Jul 5, 2009 | 04:46 PM
thewarmachine
Bump...
Old Jul 5, 2009 | 06:14 PM
mynameismike65's Avatar
mynameismike65
Just have Brenspeed turn off your rear o2 sensors.
Old Jul 5, 2009 | 06:24 PM
fordchuck's Avatar
fordchuck
High flow cat is allowing measures above max levels. Both an anti-fouler and a reflash to remove the mil codes will fix this.
Old Jul 5, 2009 | 07:30 PM
thewarmachine
Thanks, fordchuck. I've reflashed my tune twice, but after about 300 or 400 miles it comes back. I'll try the non-fouler plugs.
I can't have my O2 sensors turned off because I have to pass inspection. I'm not putting the stock H back on. My Bassani X is a major, major pain to remove and reinstall. It has a slip-fit joint that connects to the over-axle pipes so it has to be slid out, and there is no room unless the mufflers are completely removed also.
Old Jul 5, 2009 | 08:18 PM
one eyed willy's Avatar
one eyed willy
you can get those at most auto parts stores,may save you some cash.
Old Jul 5, 2009 | 10:36 PM
thewarmachine
Sweet! Thanks, *****! I'll look for them at Autozone or Advance.
Old Jul 7, 2009 | 11:46 PM
fordchuck's Avatar
fordchuck
NP. Look online for a DIY. You'll need 2 for each sensor and one gets drills out and threaded into the other. They are in the HELP section at autoparts stores.
Old Jul 7, 2009 | 11:59 PM
comando2929's Avatar
comando2929
I just installed LTs on my car. The midpipe was a cake walk to get in and out.
Old Oct 7, 2009 | 12:59 PM
Rubrignitz's Avatar
Rubrignitz
I hate to dig up an old post but I'm having this exact same problem. Warmachine - did the O2 non foulers correct the CEL/allow you to pass emissions? What was the outcome?
