I've been getting a clunk on the front passenger side when go over small bumps and such. I also notice when I'm standing still and I wiggle the steering wheel back and forth I can feel a small clunk in the floor, any ideas? Strut problem or ball joint, or etc? I only have 15k on it and it's an 08.
Try tightening the top bolt on the front sway bar end link. If you jack up your car just before the front tire lifts off the ground, you will see a bolt that is behind the top part of your tire. It will take a wrench and a ratchet at the same time to tighten. I think it is an 18mm wrench and an 8 mm ratchet. The ratchet will hold the stud from moving and the wrench will tighten the nut.
This happens to mine periodically and all I have to do it tighten it (the nut tightens about 1/4 of a turn when it gets loose and starts to clunk over small bumps)
