VHT nightshades
thanx for the help guys
i dont want a shiny look to them.... its just my corners im not doing my tails
I used Nite Shade on mine. They look great and my tails are pretty dark. They actually werent as dull as i had expected... you CAN just tape them off and spray a coat or two, but it wont look as nice as if you sanded and polished them. I put on 4 coats and it ended up being too dark, but a little sanding did the trick. For best results, take them off, wet sand and spray, and then clear coat and polish. I didnt have a buffer either, but did them by hand just using a rubbing compond and they look great. Here is a link to both ways... take your pick, and enjoy. Take a look at this for a proper guide: http://smoke-tail-lights.howtocar.net/tutorial.html
how about this instead for $20?
http://www.360tuners.com/05-09fordmu...eandamber.aspx
I'm ordering a set on the 1st when i get paid. I'm all for DIY stuff...but for only a few $$$ more, I'd rather fork it over. Paint and i don't mix that well
cool, thanks. I've realized the biggest trick is really just keeping them clean. Once they get dirty at all it starts to mess with the finish. Hopefully a fresh coat will solve that, thanks again for the tip.
