question about lowering/gears
Old Aug 4, 2009 | 10:24 AM
abarker8541's Avatar
abarker8541
Default question about lowering/gears
so should i drop the gears in first and then lower it with eibachs' pro-kit or lower it and drop the gears in? will the drop affect the pinion angle to the point where it would have to be redone if i put the gears in first?
Old Aug 4, 2009 | 10:55 AM
deekum1627's Avatar
deekum1627
i think you should be fine man i plan on putting the pro kit on too soon im just waiting for shocks and struts first
Old Aug 4, 2009 | 11:24 AM
Va. Stang's Avatar
Va. Stang
do both then check your pinion angle. Then save up and buy adj. control arms if needed.I have Pros..did gear change..alls fine..
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
