IUP v. ISAP
RE: IUP v. ISAP
There are several different clusters, some with MPH and some with KPH, some with Message Center some without. However, for all intents and purposes, your car has two different choices. The one with the message center, and the one without.
To tell which one you have now, simply count the guages. If you have what I have (I just ordered a new one w/message center), you will have four guages. MPH, RPM on the outsides, and Fuel and Temp in the middle. Also in the middle will be the odometer/tripmeter. Also above and to the left of the stereo will be three blank buttons (opposite of the hazard button, etc.)
If this is what you have, you have the standard guages without the messaging center.
The one with the messaging center has all that I listed, plus two other guages. I believe they are voltage and oil pressure.
Those two guages will be in the bottom of the middle below Fuel and Temp.
The odometer will be integrated into the messaging center which is over on the right, with the speedometer. This is controlled through buttons that much also be purchased separately. They will go where those blanks are.
The message center has, for example, odometer, tripmeter, trip timer, average MPG, instant MPG graph, MyColor configuration, system diagnostics, miles to empty.
I'm still waiting on mine, so if anyone with this cluster has any corrections, please post.
I hope that helps and clears up some of your questions. I'm sure if you stop by the dealership they'll show you one.
RE: IUP v. ISAP
Thanks for the info -- you posted your answer as I was posting my question. I ordered mine w/ ISAP. Dealer did not have one on the lot, but advised that I would get the message center. I am confident that the info on this board is FAR better than what I got at the dealership.
I know that the ISAP does not have the "my color" feature, but I am still unclear as to exactly what my car will have. Mine is a convertible and I was wordered that the chrome finish that comes w/ the IUP would create a glare when riding w/ the top down in the Florida sunshine.
RE: IUP v. ISAP
If you got the ISAP, and unless the dealer did some kind of crazy stunt to get you just the upgraded guage cluster (I doubt they did) then you wouldn't have the message center.
I think the ISAP and the IUP are totally independent of each other. You have one or the other... or neither I guess, but I haven't seen one first hand that has neither.
Anyways, I didn't have a choice for the IUP, either. I only got about two months ago and I didn't have any options other than what was on the lot... that's why I'm ordering the clusters.
So what will you have as far as the guages/message center goes? Like I said, unless they did something to work it out for you to have the message center you will have:
Speed, Tac, Fuel, Temp and a simple odometer/tripmetter toggler with a reset button.
RE: IUP v. ISAP
I really haven't had any problems with glare off the polished aluminum dash pieces. The only issue you might have is glare off the chrome rims on the gauges.
And yes, the info on this board is far better than 99% of the dealerships I've experienced. It frightens me how little they have to know about the product they sell.
RE: IUP v. ISAP
I am glad to hear you haven't had any probs w/ glare....I assumed that with the sun at your back the glare would be fierce. Of course, sunglasses (a convertible necessity) would probably take care of any problem.
RE: IUP v. ISAP
ORIGINAL: 05BlueGT
I'll have to let you know later or someone that has the IUP and answer. I have a car coming with the IUP and my current one does not have the message center.
RE: IUP v. ISAP
ORIGINAL: 2Stangs
Wow, you get your wife to be a better GT than yours, and she got you a 66 T-bird. You are made for each other!
ORIGINAL: 05BlueGT
