Sponsored by:
Sponsored by:
NT555Rs at the Track
Old 09-01-2009, 12:21 PM
VistaGT
VistaGT's Avatar
Default NT555Rs at the Track
Hey guys,
My track times don't make me happy 13.5@104.5
Just got my Nitto 555r drag radials in 275/40/17 for my stock rims.
I want to go to the track soon and need some tips what do you guys got for me??
.....mods are in sig thx!
Thanks!
VistaGT is offline
Old 09-01-2009, 02:04 PM
Jizz
Jizz's Avatar
What 60' times are you getting on the stock tires?
Jizz is offline
Old 09-01-2009, 02:10 PM
VistaGT
VistaGT's Avatar
2.0 60's......mind you not 2.000 but not 2.1 either. I don't have exact 60's
Also it's not stock tires. These are with the 285 Nitto 555s. They still don't hook well. I've also been told that the 18x10 deep dish rears are slowing me down with rotational mass.
VistaGT is offline
Old 09-01-2009, 09:44 PM
VistaGT
VistaGT's Avatar
Nobody???
VistaGT is offline
Old 09-01-2009, 10:40 PM
adidasUNT8
adidasUNT8's Avatar
Forgive me if I'm missing something but what's the difference between 2.0 and the "mind you not 2.000" same number right?
adidasUNT8 is offline
Old 09-02-2009, 08:22 AM
Jizz
Jizz's Avatar
OK my thoughts...
I was getting 2.0s on my car (auto at the time) then I got Dunlop FM901s (very sticky street tires). Dropped to 1.8s. Put in a 3600 stall and dropped to 1.6s. This was on 17" wheels.
I guess my question is are you blowing away the tires? Or is the clutch the weak link?
Jizz is offline
Old 09-02-2009, 08:46 AM
VistaGT
VistaGT's Avatar
Okay then it should have been 2.0x.....When your really into the times the difference between a 2.00 and 2.09 is big. I was trying to be accurate
Originally Posted by Jizz
OK my thoughts...
Yes, the tires do not hook up at all for me on anything but an easy launch when i clutch slip. I've gotten the 2.0s doing that and 2.2, 2.3s etc when I try and launch hard. Second gear chirps hard no matter how first hooks. Each gear is shifted at 6500rpm(just started this last time) though the 13.5 was shifting a 6k even.
VistaGT is offline
Old 09-02-2009, 08:55 AM
Jizz
Jizz's Avatar
Personally if you are going to get really serious get some racing rims (like Weld etc..) and DR.
But IMHO if you are looking for 12/11s then just get some good stiky tires on your rims - or maybe some 16" v6 rims with tires. With the stock clutch you shouls see 1.8s on your rims with DRs no problem.
Jizz is offline
Old 09-02-2009, 11:52 AM
avengence
avengence's Avatar
You should get some better times if your 60' times are 2.0. Mine was 13.53 when my 60' times are 2.2x
If you get 2.1 you should be under 13.5 and if you get 2.0 you should be 13 flat as far as i know.
avengence is offline
Old 09-02-2009, 03:59 PM
VistaGT
VistaGT's Avatar
Yea idk, i figured better times too but that's all the car has managed....mind you that was my fourth run ever at the track and all my subsequent runs have been in the hot weather. I did manage a 13.6@102 in 85-90degree summer heat with a 2.0 60'. That was with shifting at 6500rpm so maybe it does help, I wont know until I go next with hopefully some decent temps
VistaGT is offline
Quick Reply: NT555Rs at the Track
