CAI without a tune?
Old Sep 7, 2009 | 12:42 PM
18TO1's Avatar
18TO1
Default CAI without a tune?
I just bought a Steeda CAI Kit for my 09 GT and I noticed it says that you should not install it without retuning the factory computer.
Has anyone installed one without a tune??
Thanks
Old Sep 7, 2009 | 12:51 PM
cummins cowboy's Avatar
cummins cowboy
I think you see more power with a tune than a CAI, the CAI doesn't really add much
Old Sep 7, 2009 | 12:54 PM
18TO1's Avatar
18TO1
Yea.....but will it throw any codes without a tune?
Old Sep 7, 2009 | 01:00 PM
americaniron's Avatar
americaniron
Needs a tune to run properly. Or else just leave it stock.
Old Sep 7, 2009 | 01:01 PM
crescent_wrench's Avatar
crescent_wrench
I'd put my money on it.
Old Sep 7, 2009 | 01:02 PM
ptaylor_9849's Avatar
ptaylor_9849
If you put on a CAI without a tune, your car will be getting more air than fuel and it will throw a check engine light. If you change the tune and keep the stock air box it will throw the "wrench" code on your dash and put the car into limp mode. You need both.
Old Sep 7, 2009 | 01:06 PM
Nuke's Avatar
Nuke
Cai w/o a tune nets roughly 4-8 RWHP. Plus, THAT CAI, untuned, will throw a CEL for running lean and can eventually harm your engine.
CAI & tune combo will net you roughly 15-25 or more RWHP.
Old Sep 7, 2009 | 01:11 PM
18TO1's Avatar
18TO1
Thanks guys I will just wait for a tuner then
Old Sep 7, 2009 | 01:34 PM
TAMPAGT07's Avatar
TAMPAGT07
I started mine up for a few seconds, when I got my intake, and it ran really rough. I then shut the motor off real quick. I would not reccomend running it like this.
Old Sep 7, 2009 | 01:50 PM
socalwrench's Avatar
socalwrench
Bottom line- if the MAF sensor is changed OR the MAF sensor area is changed (IE the intake tube diameter)- a tune a needed.
jwog666
Dec 27, 2021 08:09 PM
lovesilver
Members Mustangs
May 9, 2019 09:18 PM
baddog671
Jul 26, 2016 01:20 PM
Explosive
Oct 2, 2015 07:45 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
