Pass. side window
Old Sep 8, 2009 | 11:36 AM
gedyup's Avatar
gedyup
Unhappy Pass. side window
I have an 05 GT and the right door window has been working just fine and the other day i noticed that it will not go up in auto( when you pull the switch all the way up and let go) and it will not go up after shutting the door. Was just woundering if anybody else has had this problem and what you might have done to fix it. The window does work in auto going down just not up. Thanks in advance for any help with this. Jerry
Old Sep 8, 2009 | 11:48 AM
Nuke's Avatar
Nuke
The Owners Manual has a recalibration procedure that should fix that. It's pretty simple.
Anything else acting up? When our batteries start getting weak or alternators begin to fail, all sorts of electrical gremlins pop up.
Old Sep 8, 2009 | 02:52 PM
dunebuggydude11's Avatar
dunebuggydude11
th owners manual says to shut the door, turn the key on (you don't have to start the car), then roll up the widow all the way and hold the switch up for a few seconds. the same thing happened to mine and that fixed it.
Old Sep 8, 2009 | 03:46 PM
TWOKOOL's Avatar
TWOKOOL
The exact same thing happened to me this weekend. Good to know there is an easy fix out there. Once again, that's you MF'ers
Old Sep 8, 2009 | 03:47 PM
SirKnightTG's Avatar
SirKnightTG
Yeah recently my alternator started failing and it was causing a cam position sensor code to throw. I'd also get a lot of mis-fires so the car would buck and I could watch the voltage as I drove go from the low 13's to the low 12's. It was all over the place.
Old Sep 8, 2009 | 06:15 PM
TWOKOOL's Avatar
TWOKOOL
FYI
tried the key on hold the switch thing, and guess what.........magic.
good call guys
Old Sep 9, 2009 | 08:52 PM
gedyup's Avatar
gedyup
Talking
Thanks everybody for the info, tried the holding the switch thing and it works like a champ. Thanks again
cr620
Oct 3, 2022 10:18 PM
jwog666
Dec 27, 2021 08:09 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
b8checker
Oct 8, 2015 12:55 PM
b8checker
Sep 30, 2015 07:11 AM
