Maybe a stupid question Re: HIDs
From my research on the topic, it seems that HID bulbs are very similar to those used in HDTVs and the like (their life length can be effected by the number of on/off cycles). I'm thinking of getting a conversion kit for my fog lights to match the factory HID system that came from Ford. But the question is will these types of lights be adversely affected by coming on when I unlock the door, then shut off for a short period only to come right back on again when the engine starts? I assumed that was the reason they moved the perimeter lighting feature to the fogs when you get the factory setup.
The manual in your car states how to disable the perimeter lighting feature if you want to. I keep mine enabled even though I have HIDs. To disable it, you just have to do a couple of key cycles and pressing the lock/unlock on the drivers door in a certain order. It only takes 30 seconds to do.
You'll also save the lifespan by using a kit with ballasts that actually have instant hot re-strike ability like ours do. This saves unecessary strain on the bulbs by limiting starting currrent to what is needed for breakdown voltage of a warm bulb rather than the full charge needed for a "cold" bulb.
https://mustangforums.com/forum/vend...solutions.html
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
