anyone with roush rear springs only
I plan on just replacing the rear springs just to level the car. i do not race and dont care for better handling. I just want to know if I do install the roush rear springs will I need camber bolts or an adjustable panhard bar. Tires are expensive and I would hate to have them wear faster.
There is no camber adjustment for the back since it is a solid axle. You dont need a panhard bar or anything unless your axle is off to one side really bad. Just be careful with the ABS sensors if you take them off, they break real easy.
If you just changed the springs you will be good and you dont need an alignment or anything.
I've got them and needed an adjustable panhard. Also went with new shocks. Then it was LCA relocation brackets. Then LCA's.
My rear wasn't exactly centered before hand, the slight drop did make it worse. The shocks were a preference, the rear bounced around too much with the OEMs. Then came the LCA issue, I wanted them level so bought the J&M relo kit. Stock arms did NOT work work with the pair they sent me (they basically told me I was wrong even though I tried with the OEM and GT500 lca's, so they tried with four sets...no more $ going their way) so I went with Che's.
So you'll fall somewhere between where I am and not needing anything
damn. well what kit has the lowest amount of lowering in the front and can level the back with the front? my driveway is pretty steep and i can barely make it without scraping because of my lip. any suggestions?
I believe the Roushs are popular because they are spot on for leveling out the car. Any spring that gives less of a drop is not worth paying for, what exactly would be the point?
Any time you lower a car there are going to be differences in ride quality and handling, those that tell you otherwise probably can't tell the ride difference between a school bus and a BMW. Some can tolerate the difference, others can't.
A week after installing the springs I wanted to take them off due to the harshness or more specifically the unequalness. Concrete roads were unbearable, but back curvy roads were awesome. The rear end lost its tendency to roll over in corners, but added a tendency of 'rocking horse' front to rear. The spring rates in the front and rear are now different, so they both handle bumps differently, the front is mellow the rear bangs. If you don't want to lower all four corners, that's just how it's going to be.
Now after nearly a year everything is smoother, perhaps broken in. Maybe find a used set and try em out, the install is cake and if you hate em then take em out. Or find someone local with them and go for a ride.
Your definition of real harsh is most likely not the same as mine or the next guy.
