JLT fitment issues. Help!
Old Sep 28, 2009 | 08:23 PM
hardcore302's Avatar
hardcore302
Unhappy JLT fitment issues. Help!
I'm getting a nasty burn in the hood insulation above the 90 degree bend (that goes to the throttle body) and above the air filter because they are both rubbing the hood insulation. The air filter itself is also burning.
I've tried my best to adjust the fitment, but to no avail. This is my second air filter. The original was too far gone.
as anyone had a similar problem that could give me some tips? Thanks!
Old Sep 28, 2009 | 09:02 PM
rdsx18's Avatar
rdsx18
Burning? My elbow rubs but doesn't burn, and my filter doesn't rub at all on my JLT. Try repositioning it some.
Old Sep 29, 2009 | 06:25 AM
partsbill's Avatar
partsbill
my elbow rubs alittle but not that big of a problem, I did have a issue with the filter rubbing, I fixed it by triming the heat shield down where the filter would sit down alittle lower which gave me the room that I needed for the filter to clear.
Old Sep 29, 2009 | 07:34 AM
1morepart's Avatar
1morepart
i had similar issues when i had a jlt(the rubbing,no burning)...i choked it up to, you get what you pay for,imo.....i would consider a better fiting cai like a c&l or steeda..
j
Old Sep 29, 2009 | 10:32 AM
MELLOWYELLOW06's Avatar
MELLOWYELLOW06
I had fitment issues on mine. It was more with the sheild not the filter. Had to trim and sand down a bit to fit better. Little finesse will make it all work out.
Old Sep 29, 2009 | 10:37 AM
hardcore302
Thanks! PS where did you get that shroud? I don't have the cushoning like you do.
Old Sep 29, 2009 | 10:54 AM
partsbill's Avatar
partsbill
it's the JLT heat shield with some weatherstripping that I put on myself.
lincolnshibuya
Dec 8, 2015 04:37 PM
UrS4
Sep 30, 2015 10:13 AM
mungodrums
Sep 29, 2015 09:18 PM
mungodrums
Sep 28, 2015 05:45 AM
kevsgt
Sep 9, 2015 06:20 AM
