steeda UD pullies install help
Old Oct 1, 2009 | 02:44 PM
sharkbait20's Avatar
sharkbait20
Default steeda UD pullies install help
does anybody that has installed the steeda Underdrive pullies still have the long "guider" crank bolt (to seat the pully onto the crank) that they could lend me?
in short. can anybody lend me the long installation bolt so i can do my pullies?
Thanks
Old Oct 1, 2009 | 02:54 PM
Jokeurmnd's Avatar
Jokeurmnd
Where are you located?
Old Oct 1, 2009 | 02:57 PM
gdear66's Avatar
gdear66
Be real careful with that bolt when you get it. I installed those on my '02 GT and when I went to take that bolt out, it stuck and then broke in the block. I had to have it drilled out. There seems to be a real fine line between getting it seated properly and a little too far in. The kits can't be that much different for the s197s.
Old Oct 1, 2009 | 03:02 PM
replica's Avatar
replica
The UPD install scares the hell out of me because I'm used to Hondas. Does it replace the crank pulley? Do you have to make sure everything stays TDC and it takes the power of a demi-god to break the crank pulley bolt loose?
Old Oct 1, 2009 | 09:30 PM
sharkbait20
im in CT. i figure shipping via USPS shouldnt be too expensive
if anybody has input... is it possible to do the install without the longer bolt?
thanks
Old Oct 1, 2009 | 11:27 PM
brunobluto's Avatar
brunobluto
thanks
I put my UDPs in about 4 years ago and honestly dont remember much about the install process. But i think that longer bolt was about 3/4 inch longer than the stock one. It was used to push the new pulley onto the crank and then removed. So i would say take the stock bolt to a hardware store and get a slightly longer one, making sure its the same thread pitch. get a few difffernt lenghts so you'll have several to chose from. I do remember the hardest part was getting the old pulley off, but then on was easy.
Old Oct 2, 2009 | 12:21 PM
NJ3's Avatar
NJ3
If you have an Auto Zone near you could use one of their loaner tools.
http://www.autozone.com/autozone/cat...uestid=2366868
Old Oct 2, 2009 | 01:40 PM
sharkbait20
yikes, 45$ for a rental??!!
Old Oct 2, 2009 | 02:11 PM
Casey4s's Avatar
Casey4s
Nope, just pull it off anywhere, and the key slot only goes on one way. The pulley does not afftect the timming at all.
Yup the bolt is pretty tight but an impact pops it right out.
Old Oct 2, 2009 | 02:16 PM
Casey4s's Avatar
Casey4s
You will never get a bolt at a hardwarte store or auto parts place. I have an unused one I would send you but I am in VA. How soon do you need it? I used a balancer installer because I feel it is a better (safer) method.
It is also highly recommended by FORD to replace your stock crank bolt because it streches during the installation torque sequence. The FORD part number for the bolt is: F 5RZ 6A340 B.
