Trunk button
Old Oct 12, 2009 | 08:28 PM
DamnItzHenry's Avatar
DamnItzHenry
Default Trunk button
http://www.cherod.com/mustang/HowTo/TrunkRelease.htm
I tried to add this but, was unable to get it to work. I had already attached the ground wire and have my other wire wrapped up around the white with pink stripe wire, but it just won't work. Any suggestions?
Old Oct 12, 2009 | 08:54 PM
Johnboy7701's Avatar
Johnboy7701
Is your ground wire on straight metal? Make sure its on a good ground try some different places. Also make sure you have the right wire for the power. I think when I looked I had 2 different pink wires or one that looked pink but was actually orange.. Just double check everything and give it a couple go arounds... should work mine has with no problems...
Old Oct 13, 2009 | 12:12 AM
DamnItzHenry
I'm sure its the right wire, because I also saw the white/orange wire your talking about. It might just be my ground wire then. I'll give it another go tomorrow
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
firehorse02
Nov 16, 2015 11:28 AM
lincolnshibuya
Oct 6, 2015 08:45 AM
Sep 30, 2015 12:39 PM
