What are the differences?
Old Oct 19, 2009 | 02:40 AM
Tylus's Avatar
Tylus
Technical Service Bullitin
basically a problem pops up. Ford Engineers do some Pow-Wow stuff...and they come up with a procedure to correct/fix the issue.
Like with the Window roll-down feature. Was intended as a valet function. Ended up causing issues, so the later 2005 and all 2006-2009 cars had it removed. Sucks, because it's a nifty little thing
Old Oct 19, 2009 | 02:46 AM
Matafy's Avatar
Matafy
Oh okay I get it now, thanks for explaining that. But do you see a real major difference between the two model years at all?
Old Oct 19, 2009 | 02:56 AM
Tylus's Avatar
Tylus
nah
colors changed
added a appearance group
but the motor/tranny/axle/brakes...all the important stuff is the same from 2005-2009. just very very slight stuff changes from year to year as vendors changed.
you can take the mechanicals from a 2009 and it will work on a 2005 model. Except the electrical. that is a tricky subject. Ford likes to tweak stuff every year. almost always compatible though with other years.
sorry if it seems like I'm dancing around your question. I could answer a specific interchangeability question easily. But your basic question is too generic for a straight up answer.
I know a few people with 05's, and they have been relatively great cars. With age comes some issues, but that is true of anything.
just be careful what you are buying. look for burned rubber in the fenderwells, check the clutch play, odd sounds/creaks/groans
you know...the basics
I personally would try to grab a 2006 model. newer is almost always better IMO. You get the benefits of the tweaking, and the newer usually have fewer miles.
Old Oct 19, 2009 | 02:57 AM
Art161's Avatar
Art161
Originally Posted by Matafy
Im sorry that Im a noob, but what is the "TSB"?
TSB=Technical Service Bulletin
A bulletin put out by Ford explaining how to fix a known problem area, or saying that the problem is not really a problem, but is "normal."
Old Oct 19, 2009 | 05:11 AM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
So case closed...and the thread too.....
Dokilar
15
Oct 16, 2015 08:13 PM
breaking
Oct 2, 2015 01:27 PM
UrS4
Sep 30, 2015 10:13 AM
mrappe
Sep 26, 2015 10:16 AM
