Shift Help
Old Oct 20, 2009 | 02:45 PM
GunMetalGT08's Avatar
GunMetalGT08
Default Shift Help
Ok the other day i was driving behind this cement truck and stuff started falling out so i shifted into 3rd and speed past him. When i shifted from 3rd to 4th, it was a hard down shift, my gears grind. Now this doesnt happen when i put it into 4th normally only when it is a hard down shift.
This doesnt happen when i do the same for any other gear.
Is this a problem? anyone else experience this?
i have a stock no after market done.
Thanks in advance!
Old Oct 20, 2009 | 03:55 PM
VistaGT's Avatar
VistaGT
3rd to 4th would be an upshift..... Your gears shouldnt grind no matter if it's a hard upshift or downshift. You could have prematurely disengaged the clutch
Old Oct 20, 2009 | 11:38 PM
GunMetalGT08
Alright cool thanks! i guess ill have to take her in to the dealership.
Old Oct 21, 2009 | 12:17 AM
Tylus's Avatar
Tylus
1 of 2 things are happening
1. You aren't fully using the clutch
2. the clutch isn't disengaging fully when you depress the pedal.
my money is on it being a driver thing. if the clutch itself were messed up, you would experience that grinding in all 5 gears.
I know I've ground my gears 1-2 times when I was trying to speed shift and my foot was faster than my hand.
see if you can get the problem to occur again
Old Oct 21, 2009 | 12:20 AM
GunMetalGT08
I thought of that so i pressed the clutch down all the way and then shifted into 4th hard and it started to grind. I also tested that in all the other gears as well. I though maybe i am just late but it wasnt it.
Thunderball
15
Nov 22, 2015 11:49 PM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
Mustangmalo
Sep 6, 2015 05:22 PM
