Wierd leak noise developing to Knock.
Sounds like a bent rod. Ford uses crappy Metaldyne compressed powder metal rods to reduce cost. Not to mention they arent machined between the rod and the rod cap, they form them as one piece, drill and tap for the bolts...then "snap" it into two seperate pieces. JUNK!
I started trouble shooting.
a/ Span the charger no abnormal resistance
b/ Checked the oil, no residue or water.
c/ Started Checking the sparkplugs and no signs of impact
As I am working on removing the sparkplugs I drop a screw and it goes somewhere I cannot see (not on the floor.), so I jack up the car and I start feeling around..
I look at my driver side header and I see a drop of amber fluid on the bolt of cylinder 8.
I wipe the bolt only to find out that is totally loose. I feel some of the rest of the bolts and they where somewhat loose as well. I tighten up everything fired up the car... and no noise..
Just a little remnant noise possibly I need to change the header gasket as it may have burned.
What a relief.. I need a drink.
bradleyb
Nov 27, 2015 07:50 PM
KingRando
Oct 2, 2015 08:06 AM
