Time between oil changes...
Old Oct 26, 2009 | 02:25 PM
Fort LiquordaleGT's Avatar
Fort LiquordaleGT
Default Time between oil changes...
I don't exactly put a lot of miles on my car. So I just checked in Feb I did my last oil change, sine then I only put 6k on it. I try and change the oil every 7500.
So my question is, if the car is under the mileage what if the car is rarely driven, do you still have to change the oil? I know the oil industry likes to say every X amount of months, but I"m not buying it.
What say you? Should I change it?
Old Oct 26, 2009 | 02:54 PM
pwd72s's Avatar
pwd72s
What kind of oil are you running? Just my opinion, but I'd say with dinosaur oil or synthetic blended with dino, every 6 months. A quality synthetic should last a year...assuming your engine is good.
Old Oct 26, 2009 | 03:21 PM
onederful100's Avatar
onederful100
i change mine every 6 months no matter what. sometimes i only put 2-2.5k miles in 6 months but i change it anyways. it may be overkill, but that's how i roll.
Old Oct 26, 2009 | 04:26 PM
millpond's Avatar
millpond
If you want to keep the power train warrantee in effect, you have to change the oil at least every 6 months.
Old Oct 26, 2009 | 05:26 PM
JCON's Avatar
JCON
esp if the car is sitting for long periods of time, I would change it every 6 mos. I use to run AMSOIL 9,000 miles and I'd change oil about 3 times in two years
Old Oct 26, 2009 | 07:08 PM
Nuke's Avatar
Nuke
Providing you're not making frequent short trips and not allowing condensation to burn off and acids to form, then full synthetic can be left in the crankcase for a year. If you're using a blend then 6 months is about as long I'd go.
Old Oct 27, 2009 | 08:07 AM
Matrix's Avatar
Matrix
Around 94 or so GM did extensive testing on oils to determine what they would factory fill Corvettes with and also what the reccomended change interval would be. They settled on Mobil 1 as the oil and then further tested that oil. They found no difference in wear on the engine components between change intervals of 5,000 and 10,000 miles.
Obviously we are not talking about Corvettes specifically and possibly not Mobil 1 oil but the basic information suggests that modern oils are so improved as are modern engines (cleaner burning) that the old 3,000 mile rule no longer applies. Changing your oil more frequently than 5k or 6 months is just wasteful and is of no benefit IMHO. Unless you are operating in some really EXTREME conditions.
My DD is a 2001 Hyundai Elantra. I change the oil about every 6-8K with Walmart synthetic oil and a Walmart filter. Im at 200k and it still runs perfectly. It uses absolutely no oil between changes.
Old Oct 27, 2009 | 08:21 AM
S281 E's Avatar
S281 E
^+1 with the high efficiency motors we have now a year or 10K should do the job, but its always better to be safe than sorry.
Old Oct 27, 2009 | 08:50 AM
Starfire's Avatar
Starfire
I change every 5000 with Mobil 1 and a new filter, I might be able to go longer but hey what's 30-35 bux to keep a car running good.
Old Oct 27, 2009 | 11:04 AM
08SilverStang's Avatar
08SilverStang
Wow i'm in the minority here, I change mine every 3000 religiously
