What do I need to buy to lower my stang?
I just put new wheels and tires on my 08 v6 (20x10 back & 20x8.5 front). I want to make it lower, what do I need buy? just the lowering springs? about $249 I think from american muscle. Anything else that I need? thanks.
I did mine saturday. Just the springs, 'cause I'm broke right now. Used H&R springs. Looks really good and the handling is ok, considering I'm using the stock shocks. When I get some funds I'll do the shocks and panhard, but for now I'm happy. Car looks soooo much better, even with the stock wheels.
+1 on doing both shocks/struts and springs and while your at it get a panhard bar. I couldn't buy it all at once so bought each when I could than once I had them all I installed them than got alignment than I was good to go!
JMO Good luck!
JMO Good luck!
When lowering your car, an adjustable panhard bar is highly recommended to maintain alignment. If your are running lower control arms, I would also recommend relocation brackets, they add a bigger moment to the axle to reduce wheel hop. New shocks and struts are also a good idea is money is not an issue.
My personal favorites are steeda ultra-lights, tokico D-specs, and steeda panhard bar, control arms, and BMR relocation brackets.
What labor costs should I pay just to do the lowering springs? I called 3 shops and 2 of the wanted around $350 just for labor, the 3rd shop wanted $200 does this sound high or normal?
ccdguy
Sep 19, 2015 05:20 PM
