delete kit help
Old Oct 28, 2009 | 02:31 AM
GunMetalGT08's Avatar
GunMetalGT08
Default delete kit help
Ok i want to do Ghost Lights just wondering if i can buy this front grill delete. Will i be able to do it? do i need a certain grill? Help!
Thanks!
it's from this website: http://www.mrbodykit.com/accessories/billet.htm#2005
Any comments about it or is there a better more reliable site?
Thanks again
Old Oct 28, 2009 | 02:52 AM
Shadow7874's Avatar
Shadow7874
Thanks!
Thanks again
i think ive seen it done on that grille but i cant say for sure. If you could do it with the bullitt grille that would be sweet
Old Oct 29, 2009 | 12:37 AM
CorruptedDemon60's Avatar
CorruptedDemon60
I have seen it done. But not sure what grille it was. Oh and tinting the fogs helps alot to hide them once you put them behind the grille.
Old Oct 29, 2009 | 10:53 AM
StangMan001's Avatar
StangMan001
That looks like the grill that I bought, with the pony emblem. The instructions are a bit hard to follow. I tinted my fogs & zip tied them. All you do is take your grill off and attach the new one. Hope this helps.
Old Oct 29, 2009 | 02:32 PM
GunMetalGT08
Yeah that is AWESOME!!!
Was it a tight squeeze to put the lights behind the grill? Did you have to adjust anything to put the light behind it or was it just simply putting the lights behind the grill?
Thanks.
Old Oct 30, 2009 | 08:39 AM
StangMan001
Yes it is a bit tight in there, but I still zip tied the fogs up. You have to relocate the horn also. No adjusting, but it takes a bit to align the fogs so they are both aiming the same way. Hope it works out.
Old Oct 31, 2009 | 03:23 AM
GunMetalGT08
thanks for your help!
Old Nov 1, 2009 | 09:04 AM
StangMan001
no problem. Glad to help. Post up those pics when she's done.
Old Nov 1, 2009 | 07:07 PM
SaddleUp's Avatar
SaddleUp
I think tinted fogs behind the grill look soooo good. This is one of my very favorite looks on these cars. Very sexy.
Old Nov 1, 2009 | 07:36 PM
Stang-aholic's Avatar
Stang-aholic
doesn't that restrict flow of air to the engine? i know the stocker is worse than the billet tho.
what does the fogs press against? the grill and the radiator? is the harness pinched or crammed in?
it just sounds like a bad idea....but looks killer!
