Console kick panel removal
Old Oct 29, 2009 | 07:28 PM
Rubrignitz's Avatar
Rubrignitz
Default Console kick panel removal
Is there a way to remove these w/o first removing the center console? Need to replace my HU fuse (or maybe even my HU )
don't feel like pulling the entire console out tonight...
Old Oct 29, 2009 | 09:24 PM
usc49erfan's Avatar
usc49erfan
not quite sure which fuse you are in reference too, but the interior fuse box is on the passenger side, at least in an 06, and you have to remove the kick panel that has the mustang lettering on it, then just open the box
Old Oct 29, 2009 | 09:36 PM
Rubrignitz's Avatar
Rubrignitz
I gave up on it being a quick fix. I've now removed the center console, both kicks, ac/front panel and pulled the entire head unit out. Checked all connections, fuses, etc. Don't have time tonight but will use the dvm tomorrow and see if the HU is getting power. If it is, my HU has failed...
Maybe I'll upgrade to the ida-x305. this was the first usb HU, the ida-x001 I installed 3 years ago and couldn't recall if there was a way to get the kicks off w/o the center cosole.
Old Oct 29, 2009 | 11:30 PM
HypromanGT's Avatar
HypromanGT
I don't believe there is a way to do it w/o removing the center console. Once you've done it a few times it's not too much trouble though
Old Oct 29, 2009 | 11:37 PM
Casey4s's Avatar
Casey4s
If I remeber when I took mine out you actually have to remove the Kicks to get the console out, so you shouldn't have to remove the console at all. But the console comes out easily any way.
Old Oct 30, 2009 | 11:36 AM
157dB's Avatar
157dB
Cut & Paste Expert
Console first, kicks second.
jwog666
Dec 27, 2021 08:09 PM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
Explosive
Oct 2, 2015 07:45 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
