idle speed
Old Nov 1, 2009 | 05:56 PM
top00cat's Avatar
top00cat
Default idle speed
what is the difference between idle drive and idle neutral? I have hanging RPMs that are driving me crazy
Old Nov 1, 2009 | 06:19 PM
hammeron's Avatar
hammeron
i've been curious about that too.
Old Nov 1, 2009 | 06:23 PM
Nuke's Avatar
Nuke
It's possible your stand-alone CAI is causing your PCM some grief. A good tune would probably help.
But you may want to try resetting the adaptive learning by disconnecting the battery for 20-30 minutes first. Just be aware that you'll need to put about 10 - 20 miles on the car for it to begin relearning and hopefully settle down.
Old Nov 1, 2009 | 06:41 PM
top00cat's Avatar
top00cat
well i had problems with it before so doug sent me a new tune for 91 octane. fixed the problem but when he sent me the new tune in 93 octane it started again. I thought adaptive learning would fix it too but no such luck
Old Nov 1, 2009 | 06:45 PM
top00cat's Avatar
top00cat
the rpms hang at 1000 when i put the car in neutral and come rolling to a stop. they sit there for a few seconds then drop back down to 750. i am just frustrated because it seemed like doug nailed it on the head with the 91 octane
Old Nov 1, 2009 | 06:53 PM
hammeron's Avatar
hammeron
ok that is what i suspected.
there seems to be a small tradeoff, between
a tune where the idle hunts around too much
and a tune where the idle hangs a little more
when coasting to a stop.
my current tune hangs more and slowly comes
down as vehicle speed decreases and when
stopped, it goes to the idle nuetral setting.
there is a happy place for the tune, you just have
to find it.
Old Nov 1, 2009 | 06:58 PM
top00cat's Avatar
top00cat
that must be it. i thought it may have had something to do with the two idle speeds on adjustable options
Old Nov 1, 2009 | 07:04 PM
hammeron's Avatar
hammeron
top00cat, you ever consider getting the
sct pro racer package? i'm getting it in
a couple of weeks, mainly for educational
purposes.
at some point i'll be able to answer these types
of questions, with confidance.
Old Nov 1, 2009 | 07:07 PM
top00cat's Avatar
top00cat
didnt know anything about it but i love to learn about my car so yes i will absolutely consider it
4cylinderplus2
Oct 9, 2020 07:45 PM
TCStangerv6
Oct 11, 2015 05:57 PM
svfetter
Oct 5, 2015 11:39 AM
BeatnikFink
Oct 1, 2015 08:00 PM
MacSerio
Sep 27, 2015 01:05 PM
