HID Headlights
Old Nov 17, 2009 | 12:52 AM
codykthekilla's Avatar
codykthekilla
Default HID Headlights
Just out of curiosity, if I get the factory hids out of an '08 mustang will they plug right up and work properly on my '08 GT/CS? Also, does anyone know where I can get a black billet grille that sits in front of the fog lights, as in you cant see the fog lights until I turn them on? Thanks
Old Nov 18, 2009 | 09:53 AM
Retrosolutions's Avatar
Retrosolutions
Former Sponsor
They will flicker without the use of the proper wiring or reprogramming by the dealer (if possible to deactivate the PWM on the low beams). They may work and not flicker, although unlikely, if they did function as such the ballasts would prematurely fail.
Old Nov 18, 2009 | 12:09 PM
rford426's Avatar
rford426
You need the hid wiring harness and a few diodes from radioshack..theres a few write ups...I did it the same way as the write ups say and don't have any flickering on hi's or low's...let me know if you have any questions!
smokinAMD's Avatar
smokinAMD
http://steeda.com/products/ford_oem_HID_upgrade_kit.php
http://steeda.com/directions/162-S19...steeda_hid.pdf
According to the above links, it will work fine, provided you supply it with enough power, hence the upgraded harness it comes with.
Old Nov 18, 2009 | 12:15 PM
rford426's Avatar
rford426
this is the guide i used...http://www.silverhorseracing.com/ins...%20Mustang.pdf -
Old Nov 18, 2009 | 12:23 PM
smokinAMD's Avatar
smokinAMD
Your link = epic failure!
Old Nov 18, 2009 | 01:21 PM
xspsi's Avatar
xspsi
Try this: http://tinyurl.com/yk4mmmh
Old Nov 19, 2009 | 07:17 AM
wilkinda's Avatar
wilkinda
2010 Section Moderator
I am going to move this back to the proper section....
StalkerGT
Nov 28, 2015 03:09 PM
Seanam
Oct 4, 2015 10:15 AM
Drastang
Sep 29, 2015 03:31 PM
kawiguy827
Sep 22, 2015 10:52 AM
Mobiusone stang
Sep 7, 2015 08:46 PM
