Vogtland spring pics (GT)
Old Nov 22, 2009 | 02:47 PM
Rubrignitz's Avatar
Rubrignitz
Default Vogtland spring pics (GT)
Anyone have pics of these springs installed on your car? Please post them. Thanks!
Old Nov 22, 2009 | 02:59 PM
KeneticEnergy's Avatar
KeneticEnergy
Old Nov 22, 2009 | 04:37 PM
Rubrignitz's Avatar
Rubrignitz
Those look really good!!! I ordered some of these from Sam Strano last week to replace my Steeda competitions which are a bit firm for my DD.
Old Jan 5, 2010 | 02:59 PM
Roy_R's Avatar
Roy_R
I don't understand how it its 1.3/1.3 why the rear is not higher??? I'm about to buy spring and I can't make up my mind on the Eibachs or the Vogtlands??
Old Jan 5, 2010 | 03:12 PM
Rubrignitz's Avatar
Rubrignitz
I eventually went with Steeda Ultralites (at Sam's recommendation w/ my other components and stated needs) over the Vogtlands. I've been very happy with them so far.
As for the 1.3/1.3...I'm not so sure every spring manufacturer uses the same guidelines. And every car is different as well.
Old Jan 5, 2010 | 03:51 PM
KeneticEnergy
it might just be that picture and the angle. but yes the rear is a little higher. as far as how much exactly, i dont know because i am a retard and got 255/45r18 in front and 275/40r18 in rear so the rears are half an inch shorter so the gap looks bigger
heres a better pic. the tire would be a little more flush with the fender if i had a true 285/40r18 like an f1 supercar or kdw2 , but id still have the tiniest bit of gap.
my vogtland/koni setup rides way better than my buddy's eibach/tokico setup. tokico is a good damper so i'll lay the blame on the eibach springs.
Old Jan 5, 2010 | 05:01 PM
Rubrignitz's Avatar
Rubrignitz
I'd tend to gravitate towards the Konis making the most difference in ride.
I've ridden in several cars with Eibach, both pro-kit and sportline setups with Konis and d-specs (along with a few coilover setups) and the Koni cars all rode "better" to me. IMO, the damping is much better with the Konis. The Tokicos are a bit skittish. Don't get me wrong, both are immensely better than stock but I can feel the difference in damping quality between them.
I should have purchased the Konis from the get-go. I will eventually.
Old Jan 5, 2010 | 10:37 PM
rcj2000's Avatar
rcj2000
i have the vogtland and they are amazing! it rides like stock if not better and im still on stock struts/shocks. the back is still a little higher than the front just like stock. they are a progressive spring and they are only 150bucks. you also dont have to worry about sag and they give you the drop immediately. dont have to wait for them to "settle" like other springs sometimes.
Old Jan 5, 2010 | 10:42 PM
rcj2000's Avatar
rcj2000
Old Jan 6, 2010 | 12:36 PM
KeneticEnergy
Originally Posted by rcj2000
this here makes me happy
GimpyHSHS
19
Dec 19, 2023 01:12 PM
CS2007
Jun 25, 2019 09:45 PM
9550
Oct 26, 2015 05:01 PM
mungodrums
Sep 28, 2015 10:54 PM
