help having issues getting spedo right after 4.10
Old Nov 25, 2009 | 03:08 PM
09blkgtcal's Avatar
09blkgtcal
Default help having issues getting spedo right after 4.10
Ok, so I got 4.10s installed by a ford dealership but at the time I was running a bamma tune and told them not to flash my car bec I would just adjust it with the sct. Now I have the stock airbox in along with the stock tune but the sct(xcal2) wont let let me modify anything. I went back to ford and he treid calibrating my spedo but on his laptop he could only tune it for 3.33's,3.55s and 3.73's. He told me that I could get a ford racing device with the stock tune and adjust it that way but I would rather not have to spend that much cash. Does anyone know of a way i could run the stock tune and have my spedo set for 4.10's. Or do you know if a tuner could send me a copy of the stock tune so I could adjust.
Thanks in advance for your input and happy thanksgiving
Old Nov 25, 2009 | 03:28 PM
mike castaldo's Avatar
mike castaldo
call JPC racing.. heres there link..http://www.jpcracing.com/Home_Page.html
Old Nov 25, 2009 | 03:30 PM
partapgti's Avatar
partapgti
you could also go to your local tuner, they should be able to make changes in the calibration to run 4.10 gear.
Old Nov 25, 2009 | 03:49 PM
Nuke's Avatar
Nuke
... Now I have the stock airbox in along with the stock tune but the sct(xcal2) wont let let me modify anything. ...
First, I don't understand why you have the stock airbox on. Did you return the airbox and tune to stock just becasue you had the dealer install the 4.10's?
When you say the Xcal won't let you modify anything... Is it letting you load the Bama tune? If your Xcal is locked out then it sounds to me as if the dealer did reflash and your strategy code has changed.
Old Nov 26, 2009 | 11:44 AM
09blkgtcal's Avatar
09blkgtcal
the xcal lets me modify the bamma tune but not the stock one. I called a tuner and hes making me a stock tune with the 4.10 adjustment. Problem solved thanks
Old Nov 26, 2009 | 02:08 PM
Johnboy7701's Avatar
Johnboy7701
Why dont you just get a tune for it... it'll run much better...
Old Nov 26, 2009 | 11:02 PM
1morepart's Avatar
1morepart
^well said
j
cr620
Oct 3, 2022 10:18 PM
Thunderball
15
Nov 22, 2015 11:49 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Bokeo
Oct 10, 2015 08:28 PM
junior04
Sep 28, 2015 10:53 AM
