hurst shifter bushings?
Old Nov 27, 2009 | 04:30 PM
one eyed willy's Avatar
one eyed willy
Default hurst shifter bushings?
its been a while since i installed my hurst, i got under the car the other day to make sure things were tight,its been getting more and more notchy. didnt know it but my hurst seems to have rubber black bushings,not poly. im wondering if thats why it is so notchy and hard to shift into second gear some times.
any know the difference and if the poly bushings woud help? are the stock bushings and hurst bushings the same size,so if i were to buy a bushing kit could i put them in the hurst?
http://cgi.ebay.com/ebaymotors/STEED...Q5fAccessories
looking to put these in the hurst maybe?
Old Nov 27, 2009 | 08:08 PM
Doogie65's Avatar
Doogie65
I actually used the stock front bushing on my Pro 5.0 instead of the poly one to help control additional NVH and doubt the use it would cause the shifter to be any more "notchy" as mine has worked great.
Old Nov 28, 2009 | 01:57 AM
Tylus's Avatar
Tylus
the rubber if anything will make your shifter shift softer
the rubber and poly bushings are identical in the fitment department if you have the Competition shifter
do you still have your stock shifter? the Competition Hurst looks exactly like a OEM Ford shifter externally (uses same stock). So if your Hurst looks like the stocker, then yeah you can slap the Poly bushings on there.
the poly bushings will really firm up your shifting and allow less deflection from the shifter when you are really hitting the gears hard
Old Nov 28, 2009 | 08:25 AM
one eyed willy
screw it,im going to a mgw
Old Nov 28, 2009 | 10:26 AM
funtimesalways's Avatar
funtimesalways
im still debating on doing the same one eyed *****, i have the hurst comp and not a fan, the thing moves up and down and vibrates louder than the shaker. thinking of either hurst billet or mgw
Old Nov 28, 2009 | 02:18 PM
one eyed willy
yup,im going to just spend the extra cash and get the mgw. i have yet to see a single unhappy mgw owner,my hurst really blows, i dont mind the notchy too much, id rather it not be so notchy but i could live with it, i just cant stand trying to slam it in gear and it wont go.so im going to replace the hurst and add some torque limiters.
Old Nov 28, 2009 | 02:25 PM
pascal's Avatar
pascal
S197 Section Modder-ator
Torque limiters will help any kind of shifters.
+1 for that.
Don't forget that you will get notchiness as well with the MGW if you want the same shorter throws.
However, that shifter will not fail you.
firehorse02
Nov 16, 2015 11:28 AM
Explosive
Oct 2, 2015 07:45 AM
guitarman376
Sep 30, 2015 05:54 PM
UrS4
Sep 30, 2015 10:13 AM
junior04
Sep 28, 2015 10:53 AM
