Sequintial's giving me troubles...Help!
Old Dec 4, 2009 | 08:26 PM
rford426's Avatar
rford426
Default Sequintial's giving me troubles...Help!
So my uncle got me some sequential's for my birthday a few months ago from american muscle I think but the left side the middle light is not sequencing but it lights up and every thing else just doesn't sequence with all the other ones... Any ideas on what the hell is going on here chime in...Im gonna try to figure out where he got them at. Thanks in advane!!
Old Dec 4, 2009 | 08:39 PM
elmo3000's Avatar
elmo3000
Sometimes the relay can play up. Try running your hazzards for about a minute, sometimes the lights need to re-sequence. I had the same issue on my sequentials on my 2009 Challenger. It did set them straight but only for a short while.... then I had to send the harness back for a new one.
Good Luck
Old Dec 4, 2009 | 08:42 PM
bigherm00's Avatar
bigherm00
If all 3 are actually lighting up at different times, just move the light sockets around until they sequence in the correct order. Don't move just the bulbs, move the entire sockets around. I had to do this a time or two to get them in order.
Old Dec 4, 2009 | 09:59 PM
rford426's Avatar
rford426
They all three light up but the sequence skips the middle one...The whole right side is perfect and the left side outer lights are sequencing normal just skips the middle one in the sequence! Is that confusing lol?
Old Dec 4, 2009 | 10:23 PM
Nuke's Avatar
Nuke
I had an issue with mine where the one side wasn't sequencing correctly. I had to unplug the one side and clean the contacts at the bulkhead connector. All was well afterwards.
Old Dec 4, 2009 | 10:27 PM
2007CalSpec's Avatar
2007CalSpec
Have you tried replacing the middle bulb? Could be one of the filaments is broken. Try swapping bulbs from the right side to the left.
Old Dec 4, 2009 | 10:34 PM
rford426's Avatar
rford426
Ill try that i have some extra bulbs.. keeo you updated
Old Dec 5, 2009 | 06:03 AM
SkyWitit23's Avatar
SkyWitit23
yeah its prolly the bulb.. When you got Seq's the bulb tend to "blow" out easyer i had to change mine couple times but no biggy took me 2 min...I bought mine from American muscle aswell, Web Electric makes them...
Old Dec 5, 2009 | 10:09 AM
157dB's Avatar
157dB
Cut & Paste Expert
Define 'lights up and everything else'.
These are 3157 bulbs with the dual filiments we are talking about.
One filiment for Clearance lights and yet another seperate filiment for Brake/Turn.
All in the same light bulb package. Modern Technology is great nowdays.
When does it give you brake filiment to indicate the bulb is still good?
Or is it just the clearance light filiment that lights?
Was it a plug-n-play or a splice in kit.
I would suspect bad connections if IDC connectors were used.
If it was installed and working, I would not think the sockets are in the wrong order...
I would tend to lean towards the burnt out brake filiment in the middle bulb.
Get the LongLife Sylvanias and replace them all while you have the assembly out.
The HAZZARD function is great for checking all your bulbs minus the third brake
light and the back-up lights. Just turn on your headlights/fogs and the hazzard flasher.
Walk around the stang and see whats not illuminating or burned out.
Old Dec 5, 2009 | 10:58 AM
rford426's Avatar
rford426
It lights up with the others but it does not get brighter with the brakes and to sequence..im gonna change the bulb today and see if that helps. And they were the plug and play kit...I solder everthing 157db anyway!!
